Originally Posted By: IndyIan
Originally Posted By: camrydriver111
In the winter shouldn't the T-stats be closed and airflow through the rad during warmup not even matter?
Engine design, oil, coolant capacities, and how badly buffered the temp gauge is will affect warmup time.
Yes, however the airflow across the engine block itself sheds heat.
The Expedition is abnormal as it has rear heat as well, which includes an entire second heater core (and all the requisite plumbing) which increases the coolant capacity significantly. So you have two blower motors pulling heat from at least 25L of coolant. The volume of coolant itself is an issue, despite it not circulating through the main rad. It is instead, circulating through both heater cores and being cooled by both blower motors, pulling the heat out of it to heat the inside of the vehicle.
I guess that what you have to do, to get 10 mpg in town!
Just ribbing you, but I guess it all does add up. Just getting the drivetrain and cooling system up to temperature from -20 is a fair amount of energy.
I think the mechanical fans do hurt warm up as well, the Tracker has never warmed up quickly and I think the fan always turning it part of that. It does also have an oversize heater core, and it by itself can pull down the engine temp at idle.
10? you are being generous, LOL!
I've actually had the benefit of seeing the difference first hand between a mechanical fan setup and an electric one. The Lincoln originally had a mechanical clutch fan on it but I converted it to a Mark VIII E-fan. The difference in warm-up time was massive, particularly in the winter. Which is why the Charger developing heat so quickly compared to the bimmer isn't surprising to me
Interesting. Makes the e-fan conversion sound even more appealing.
