Originally Posted By: kschachn
Originally Posted By: Danno
So, burning a home brewed mixture of oil in a gasoline engine has more benefits than using a top tier, high detergent gasoline, with no ethanol and higher octane.
Call me unconvinced.
Yeah, call me the same. Usually when the benefits are listed they are either vague or unmeasurable, with no supporting evidence.
I mean, I've driven cars to very high mileage and advanced age for all my driving life, and despite not using anything in the gas I still don't experience rough idle, fuel pump failures, abnormal wear, the horrors of unlubricated upper cylinders (whatever that really means), worn-out injectors or any of the supposed consequences of not using it. The OP states he gets "better combustion". Just how do you measure that?
To be fair I did once buy some Techron when I had a rough idle in my BMW, but that turned out to be a bad coil.
Just because you have used something and experienced no problems does not mean it is preventing them.
But, but, kerosene dyed red in the gas or oil is a miracle worker
