Originally Posted By: LineArrayNut
You just get past the filter and spray away? What product do you think works best and what quantity?
Yes, remove intake duct from engine throttle body and with engine running - spray in bursts. I use the whole can. Best with somebody holding the gas pedal to prevent stalling since the duct is off. Don't over do it...keep engine about 2000rpm and spray in 2 second bursts. All the cleaner goes right over the valves and cleans everything in it's path. You could also just pull a vac line and suck some seafoam or top engine cleaner for the same net effect.
