Pecan Pie Cheesecake Recipe
by GumbyJarvis - 04/06/20 05:03 AM
Dewalt DXCM251 25-Gal Oiled Air Compressor
by The Critic - 04/06/20 03:40 AM
Windows File & Folder Fix Tool
by ZeeOSix - 04/06/20 01:53 AM
$.25 washer fluid at WM
by joel95ex - 04/06/20 12:13 AM
`16 Suburban OLM never tripped due to time
by zfasts03 - 04/05/20 11:26 PM
Straight 30W [Briggs & Stratton] @ Amazon
by SlavaB - 04/05/20 10:56 PM
Bosch 3323 Premium Filter Cut Open
by TrainingPolicy - 04/05/20 10:29 PM
CARQUEST Premium Oil filter 84341 Cut Open
by TrainingPolicy - 04/05/20 10:12 PM
C-1706 SAKURA Cut Open
by QuangTeo - 04/05/20 10:07 PM
Had to smile
by AZjeff - 04/05/20 10:04 PM
Childhood friend dies
by Marco620 - 04/05/20 10:00 PM
Leftover 100LL in vehicle
by PantherFan88 - 04/05/20 09:42 PM
The good old days.:)
by A310 - 04/05/20 09:04 PM
Harvest king switched suppliers confirmed.
by Micahmcmeen - 04/05/20 08:15 PM
Mobile 1 Synthetic 15w/50 - Not what it used to be?
by NorCalHD - 04/05/20 06:21 PM
Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
KebabDad69, KMoJo, F7daved, khouan, daniell
71108 Registered Users
79 registered members (Astro14, Amkeer, 4WD, alchargo, aquariuscsm, 77GrandPrix, 6 invisible), 1,610 guests, and 17 spiders.
Topics303,661
Posts5,239,379
Members71,108
92 Camry Transmission leak/seal question #3746212 05/31/15 10:53 PM
P
PurpleT Offline OP
P
Vehicle is a 92 Toyota Camry. 2.2L with an automatic transmission. 188k original motor and transmission.
The last couple weeks I noticed what I thought was a leak coming from the passenger side CV shaft were it inserts into the differential. After cleaning and reinspecting the seal several times I have now decided the leak is most likely coming from the transmission itself. The fluid appears to be coming from where the engine and transmission are joined. Would any of our mechanics out there be able to tell me what a fair/ball park price would be to have this done a local indy shop? I am pretty sure this is beyond my mechanical abilities as it seems likely the transmission would have to be at least partially removed. Is there any other work that I should have done while it is apart?
Thanks in advance for the guidance.
Re: 92 Camry Transmission leak/seal question [Re: PurpleT] #3746218 05/31/15 11:00 PM
3
3800Series Offline
3
http://www.amazon.com/ATP-AT-205-Re-Seal-Stops-Bottle/dp/B000NVW1LM
It works very well, you insist on getting it professionally done and you feel the cost is worth it then by all means. This is just a cheaper option #2
Re: 92 Camry Transmission leak/seal question [Re: PurpleT] #3746289 06/01/15 03:13 AM
O
Olas Offline
O
It's just as likely to be a rear main seal as is is to be transmission, going off your description of the location.
Re: 92 Camry Transmission leak/seal question [Re: Olas] #3746336 06/01/15 06:23 AM
J
JC1 Offline
J
Its a 92, so I would think its not worth dumping that money into a repair.
Not sure how many hours labor the shop would charge, I'm thinking its over 10 hours. Did you search any Toyota forums for any info?
As mentioned try something to stop the leak first.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: 92 Camry Transmission leak/seal question [Re: PurpleT] #3746338 06/01/15 06:27 AM
CourierDriver Offline
If its your project car, why not fix it, no reason need be given, u just wanna keep it? Then fix it....
I'd still like to have my 67 Beetle back....life was easy then..imho 2 quarts of oil roughly ,lol
No matter what time it is,its always time for a nap
Re: 92 Camry Transmission leak/seal question [Re: PurpleT] #3747366 06/01/15 10:13 PM
P
PurpleT Offline OP
P
I have recently had the head gasket replaced, put new quick struts on, and just this weekend purchased new tires. I think at this point we are passed the point of no return. The estimate I got today was for 480 plus tax which put it right around $540
