Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
synchromesh
by hunter29 - 02/25/20 06:41 PM
Ever buy a stranger lunch ?
by Mr Nice - 02/25/20 06:18 PM
36 bucks for balancing two tires....
by Vern_in_IL - 02/25/20 05:20 PM
project farm like test for Maxlife vs toyota WS
by danez_yoda - 02/25/20 05:09 PM
Audi Q5 Transmission oil?
by John344 - 02/25/20 04:35 PM
Valvoline Modern engine
by Villalobos - 02/25/20 04:35 PM
Rust bubbles
by WA1DH - 02/25/20 04:27 PM
Which of these sub $4 filters
by jayjr1105 - 02/25/20 04:05 PM
Flaring tool
by P10crew - 02/25/20 01:52 PM
akarip, BJD2020, ToyTaco2002, EarlT500, Newbie111
70801 Registered Users
41 registered members (ArgleBargle, AZjeff, bmod305, bbhero, Bjornviken, Bighorn2500, 6 invisible), 1,117 guests, and 19 spiders.
Topics301,934
Posts5,205,767
Members70,801
xg9837 #3737452 05/21/15 10:03 PM
G
gabriel9766 Offline OP
G
so the local auto parts store has a sale on Pennzoil Platinum with a fram XG9837. I was gonna use this oil and filter on my next oil change but I'm not sure about the fram filter. Im going to use pennzoil platinum but looking online the fram XG filter has no anti-drain back valve and no by-pass valve. Don't i want thoes features on my oil filter? I mite just get a acdelco then....
2018 Mazda6 Touring 2.5L MC 0W20 7,434 (CPO)
2007 Escape XLT 3.0L 6Q MC 5W30 117K
2010 Fusion SE 2.5L MC 0w20 117K
2008 Escape XLT 2.3L MC 5w30 198K
2007 Fusion SE 2.3L- 186K MC 5W30
Re: xg9837 [Re: gabriel9766] #3737464 05/21/15 10:20 PM
Stewie Offline
Did the oem filter have them?
Re: xg9837 [Re: gabriel9766] #3737474 05/21/15 10:32 PM
R
raytseng Offline
R
why do you think it doesn't have the valve?
http://www.amazon.com/Fram-XG9837-Ultra-Spin-On-Filter/dp/B002QH42W2
this page for this part number says it has it, and not only that a "silicone" one
Re: xg9837 [Re: raytseng] #3737478 05/21/15 10:36 PM
G
G
Re: xg9837 [Re: gabriel9766] #3737529 05/21/15 11:51 PM
9
901Memphis Offline
9
According to the Fram Catalog this is correct; it contains no bypass or ADBV, but the picture clearly shows a silicone valve in the filter with the exact model number pictured.
It probably does have the ADBV, but the engine usually has the bypass valve built in on GM applications where the filter doesn't have one.
My filters don't have bypass valves either, i use XG3387A and XG3980s, as the OEM AC Delco PF47/52 filters dont have it.
2012 Chevy Cruze LT 1.4T - 69k - M1HM 5w30 + Fram Ultra
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: xg9837 [Re: gabriel9766] #3737986 05/22/15 12:30 PM
J
JBinTX30 Offline
J
The Fram XG9837 DOES have a anti-drainback valve.
It does not have a bypasss valve as it is not needed.
Also something interesting, only the XG9837 has the anti-drainback valve. Both the TG9837 and PH9837 do not have one.
16 Chevy Equinox LT 2.4
17 Nissan Pathfinder SV 3.5
Re: xg9837 [Re: JBinTX30] #3738051 05/22/15 02:03 PM
dlundblad Online Happy
Online Happy
This is odd.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: xg9837 [Re: gabriel9766] #3738059 05/22/15 02:15 PM
Sayjac Offline
...Also something interesting, only the XG9837 has the anti-drainback valve. Both the TG9837 and PH9837 do not have one.
That being the case, for whatever reason Fram decided to match the oem spec and not use an adbv on the orange can and TG, and put one on the XG.
Equivalent 9837 applications in both the Wix/NG and Purolator Classic/P1 use an adbv. Having an adbv even where not originally spec'd hurts nothing.
And this is for GM using a block bypass.
Re: xg9837 [Re: Sayjac] #3738187 05/22/15 05:28 PM
G
G
So....... should I ge the XG filter or the acdelco then?
Re: xg9837 [Re: gabriel9766] #3738198 05/22/15 05:46 PM
Stewie Offline
you didn't say what car.
If warranty covers it under fits then go for fram, or if ac delco makes you feel better do ac delco then.
No need for ultra if you are running short ocis in good weather
Re: xg9837 [Re: Stewie] #3738229 05/22/15 06:35 PM
G
G
2010 chevy impala. The acdelco was longer than the fram XG. I plan on going by the OLM.
Re: xg9837 [Re: gabriel9766] #3738508 05/23/15 05:00 AM
Sayjac Offline
Originally Posted By: raytseng
why do you think it doesn't have the valve?....
I'm thinking likely because Fram's XG9837 information spec sheet linked says NO for adbv. http://www.framcatalog.com/PartDetail.aspx?b=F&pn=XG9837
Yet if one looks at the pic supplied with the spec sheet it shows a silicone adbv, same as other XG's. And the fram rep previously commenting on the fiber 9837's with no adbv, also says the XG uses an adbv.
As for the Fram no adbv topic, there was a question once about no adbv on Fram for a 4.2L Trailblazer. After doing some research I came up with an explanation linked below.* Without repeating entirely, Fram makes distinction on whether to use and adbv depending on the year. Otoh, as I noted ealier Wix and Purolator make no distinction, they use an adbv on all the GM applications.
*http://www.bobistheoilguy.com/forums/ubb..._mi#Post3141456
And based on the information in the link it appears the AC Delco PF61/61E now also use an adbv.
Re: xg9837 [Re: gabriel9766] #3738517 05/23/15 05:14 AM
Online Happy
Does the AC Delco for your vehicle have an "e" at the end of it? If it does, I would run the next cheapest filter that meets your intended OCI's needs.
Re: xg9837 [Re: dlundblad] #3739718 05/24/15 02:05 PM
G
G
O'Reilly has on oil change special of PP and a wix filter for i think $34 + a $15 O'Reilly gift card after Mail in rebate. Would the wix filter last my whole OLM?
Re: xg9837 [Re: gabriel9766] #5347019 02/11/20 09:47 AM
daman Offline
old post, off topic, but didn't want to start a new thread quick question...
is there a over sized Fram ultra for the XG9837?
"Always"....Mobil 1
Current fill: AFE 0w30
