I have an ignition coil with an out of range resistance reading on the high side. The vehicle is missing under load when climbing hills or when you try to accelerate quickly. No codes...
Would like to change this out before any other damage could occur to module if likely.
My choices today are as always Autozone and Oreillys.
I usually tend to go with Autozone duralast, they have duralast($30) as opposed to their value craft($30). Oreilly carries the Master Pro($35) and BWD($42) available in store today or I can order either the BWD Select($39) or the AC Delco($69) which are usually an overnight wait to get to my store.
What say you?
on edit; my horse is a 1997 oldsmobile 88 with a couple hundred miles over 321,000! The coil packs are all factory original as well as the module.
What say you?
