So there I was in Home Depot looking at the Echo string trimmers. I picked up the SRM-225, which is the lowest cost ($199) straight shaft trimmer. It used to be rated for 300 hours (commercial) but is now rated for only 50 hours (homeowner use).
When I got home I looked on the website and no where in the specs is it listed that the model went from 300 hours down to 50 hours. I did find a small little blurb in the frequently asked questions that said basically the model they sell to Home Depot is typically used by homeowners instead of contractors so it is now rated for 50 hours. Echo also states that they have not changed the engine in any way and it is just as durable as before, they just rate it differently. Probably did this to appease dealers that were losing a lot of sales to Home Depot. Apparently the SRM-225 model that is sold at dealers is still rated for 300 hours.
Anyone have any experience with this trimmer? I have the older model this one replaced (SRM-210) and it is an absolutely wonderful piece of equipment. Always starts in two pulls, not one single problem in 7 years of use.
