That is a small screwdriver to be prying with, no wonder it broke!
I always use the larger screwdrivers to pry, preferably the hexagonal shaped shank screwdrivers.
The way I pry is once the tool is wedged in, instead of pulling, I twist the handle, this way should anything break, it would be the driver tip, and that can be reground on a belt grinder.
