I'm assuming that when you need it, it's not to run a welder while you fix a fence...it's needed and in anger, and you will be juggling a lot of things at the same time.
Fuel...it will run out, and tell you to get back to it...fill it up and start again.
Oil...could run out...no chance of a restart if needed.
Oil...I'd choose something 30, HTHS >3.5, and given Austin's climate, something 15W or better.
New Chevron 15W30 ? Amsoil 10W30/SAE30 as suggested ?
