Well, the Trutrack is lodged solidly in my Mustang's axle housing!
Right before I put it in, I stumbled on a thread, with a number of people [censored] about the Trutrack. Basically, that it is noisy (popping, clicking, winding, ratcheting, howling, crunching, etc). I was a little worried.
http://www.svtperformance.com/forums/showthread.php?715621-8-8-TrueTrac-Problems
I just got back from my test drive and I could not be happier with it so far! I drove around with the windows down and could not hear a single peep out of it. Conditions were perfect too, wet and slippery. The Trutrack is almost invisible in its operation, smoothly sending torque to the wheel with the most traction. Even the worse case, a sharp right hand corner in the wet, couldn't even come close to spinning up the inside tire.
I wonder whether the issues people are having, are installation related, or a quality control issue. As an engineer for a CNC manufacturing company, I can't say that I like seeing "made in Taiwan" on parts I am using, but for an assembly like this to cost $480 to your door, that's what you get. I didn't change rear gears, so I didn't have to mess with the pinion. I had planned on just matching the factory backlash, but found it to be about 0.013", which is just out of spec. The shims included in the Motive install kit are complete garbage; mainly the thicker 0.100" shims. They are essentially saddle shaped, and could act like a spring washer, rather than a rigid shim. Also, the thinner ones included are 0.010", 0.015", and 0.020". The only gives you the ability to make changes of 0.005" or more. Just not a fine enough increment to dial things in nicely. I was finally able to build a shim stack that put my backlash at 0.010" (after a lot of wet sanding!)
I started out with 85w140 Valvoline High Performance (dino), but am considering switching over to Amsoil Severe Gear down the road.
