Originally Posted By: BusyLittleShop
Better HTHS by .1 is hardly measurable in the gravity flow test of oil... higher index
by 6 is means little when anything over the viscosity index of 110 is considered very high...
"gravity flow test"...for HTHS ?
You're pulling my leg aren't you...?
If you are rationally comparing the two oils, you would pick the 5W30 unless you needed the 0W part, at which point I doubt you would be scooting in.
If you choose the oils based on
Between Mobil 1 30 grade oils the 0w30 is the most current and advance
then clearly you can discredit actual metrics, because the 0W has you all shiney eyed.
Its not plain... where do you see the level of VIIs???
Surely with a comprehensive understanding of the topic, you can intuit what's likely to have more polymers in it than not...i.e. SAE30 doesn't 10W30 has some, 5W30 has more, 0W30 has much more...it's pretty obvious.
Google VII, and Afton have some great data sheets showing how their VIIs affect lubricants.
Here's a Mobil synthetic blending guide (not a recipe for Mobil 1), just indicative recipes for different grades using Mobil's Spectrasyn basestocks.
the 0W30 recipe has a basestock viscosity (gravity if you will) of around 5.2cst, and 7% VII polymers.
the 5W30 recipe has a basestock viscosity of 6.9 cst, and 2.8% polymer additives.
So...
0W30 has 2.5 times the polymers to shear
0W30 has 25% lower viscosity basestock to back it up after they DO shear.
0W30 has nearly 5% less actual oil in the sump (replaced by polymers)
You can get back to hydrodynamics, flow, and lubrication at any time too, you keep forgetting to track that part.
So...
