Originally Posted By: goodtimes
Why would bigger pores clog first? Seems opposite.
the fluid flows through path of least resistance, which is through the largest pores. As those catch larger particles, oil get forced through progressively smaller pores which catch finer and finer particles, right until they're all clogged and you're using the bypass.
I was thinking that also, but don't think it works that way. The resistance to flow should be the same per unit area of pore, oil molecules being far smaller than a "pore." Particle are being thrown against the media all over, and are plugging up the small pores first the way I see it. If a screen with different sized holes is used to sift sand/dirt, the large holes stay unplugged longer, right? Another way to look at it is why do efficiency ratings go up for large particles and down for smaller, with the same filter? More small particles keep passing through, less efficiency for them, because the larger pores allow them to pass. Just a thought, as something doesn't seem right about the theory large pores plug first.
What you're missing to see is what goodtimes already mentioned, that is the oil will take the path of least resistance. Therefore, there is more oil flowing through the paths made up of larger holes, and less flowing through the paths made up of small holes. So the least resistive paths start to clog up quicker than the more restrictive paths. As the least restrictive paths start clogging, then the oil flow will start to redistribute itself as time goes on and the filter clogs up more and more. The way an oil filter works is not like "dirt being sifted by a screen". The oil filter media is way more 3-dimensional than that, especially with full synthetic media. A metal mesh/screen (reusable) oil filter would however work more like a screen.
