Thanks everyone for your answers! Sorry for the delayed answer, it's because the time difference.
First of all, two questions for all of you:
Are any gear oils from those I mentioned or from those you mentioned fully synthetic?
Are fully synthetic gear oils better than semi-synthetic in the same sense as fully synthetic motor oils are better than semi-synthetic or mineral motor oils?
Originally Posted By: aquariuscsm
Does Amsoil make one for your car's specs? I highly recommend Amsoil gear and transmission fluids.
http://www.amsoil.com/shop/by-product/transmission-fluid/manual/
I don't see any 75W-30 oil. But maybe the
Manual Synchromesh Transmission Fluid 5W-30 is compatible, because I see Red Line mentioning "Satisfies the gear oil viscosity requirements of 75W, 80W, and motor oil viscosities of SAE 30, 10W30,
and 5W30" for its
MTL 75W80 GL-4 Gear Oil.
Originally Posted By: antiqueshell
Pentosin MTF 2 GL-4
Castrol Syntrans 75w-80 GL-4
Shell Spirax S6 75w-80 GXME GL-4
DO NOT USE ANY PRODUCT THAT MENTIONS GL-5 AT ALL IN A
SYNCROMESH MANUAL TRANSMISSION, IT MAY DAMAGE ANY SOFT
YELLOW METAL PARTS!
Are you sure about this? If you visit Motul's official lubricant guide (
https://www.motul.com/gr/en/products/recommendation) you can see that Motul suggests
Motylgear 75W80 with an API GL-4/
GL-5 for all the Lancers from the one with the 1.5L engine to the EVO X GSR (which has manual transmission).
Is there any possibility that Motul's listing a harmful product for a car? By the way I have already used Motylgear, because when the car was new the gearbox was somewhat tight for my taste and there was actually a noticeable difference! And that's why I started this topic in the first place. If a gear oil can make a difference in the feeling of the gearbox maybe there is an even better product than the one I used, which by the way is
semi-synthetic which makes me wonder if synthetic gear oils can perform even better.
Originally Posted By: kd5byb
While my 2002 Lancer OZ Rally is quite a bit older and has a different 5-speed transmission, I've been very happy with Red Line MT-85 gear oil in the five speed tranny. I note Red Line recomends MTL for your newer Lancer.
Side question: how many kilometers on the vehicle? I've got 130,000 miles (209,000 kilometers) on mine with the original clutch. Or is this a performance upgrade?
In my particular Lancer, I *hated* the Amsoil Manual Transmission & Transaxle Gear Lube 75W-90. (This is the only Amsoil product I have ever not liked.) In the cold weather, shifting was very difficult and required a lot of effort until the transmission warmed up. When I contacted Amsoil, they suggested mixing it two quarts of the 75W-90 with something else, maybe their synchromesh fluid - was at least six years ago. This helped...but didn't fix it.
When I went to the Red Line MT-85...the difficult shifting when cold went away. Very happy with it.
Enjoy your Lancer. Ours has been a *great* little car.
later,
ben
For the performance upgrade you mentioned, read the previous part of my answer. (In short, I already used another oil which I found better than the OEM, but I thought I maybe could find an even better one by asking.
And someone raised the GL-5 concern so now I would also like to sort this out.)
The clutch is new (about 75,000 km / 46,600 miles) and is performing fine, but I get a noise which I think is the throwout bearing, so I'm thinking of replacing it. (I'm not quite sure yet though if I should change only the bearing or the whole clutch set or just let it be noisy. I read that many people change all the set even for a faulty bearing in order to avoid a future replacement of the clutch which requires the gearbox to be removed from the car.) Besides the noisy clutch, I didn't have any other problems with the car and I'm quite happy with it.
Originally Posted By: 29662
Redline MTL. I use Redline MT90 in my Toyota and I can say that it's very possibly the best gear oil I've ever used in a manual transmission.
Thanks for sharing your experience with it!
Originally Posted By: SLO_Town
OP, I strongly suggest Redline MTL. They make three different viscosities. Experiment with each to see what works best. I've used MTL in many cars with great success. Currently I use MTL-85 in my 2003 BMW 330Ci. In the BMW I also used "regular" MTL as well as MT-90. All worked exceedingly well but MT-85 seems to work best in this particular BMW. In every vehicle I've used it in, Redline transmission/transaxle oils worked really, really well. IMO, I think gears lubes are what Redline does best.
Scott
PS I've also used Redline's D4-ATF and D6-ATF in the automatic transmissions of my other cars. Same result. Redline's ATF worked noticably better than the other brands.
Is it OK to experiment with different viscosities or could using a not recommended one be bad for the gearbox?
By the way what gear oil does your BMW's manual suggest? I'm curious to see if you got the best result with the recommended grade or with another one.
I also would like to know what do you mean with "regular" bout MTL. Is it supposed to have an inferior formula compared to the MTs?
And my last question: You mentioned that you used many brands of ATF. Is it easy to mention them. I would like to see which ones you used and if they include Motul which is the only gear oil I have used so far. Thanks!
