Originally Posted By: sayjac
And you are a quality OP thread starter. In my observations, some start a thread, ask questions never to return for follow up. Your post seemed sincere so took a shot at addressing each point as best I could. Glad you read it and found it useful.
As for ZAF, I picked it out of the other LL Asian PHoats because it's usually significantly less expensive than dealer sold oem AFs. Two things I don't prefer about it is, one it's a premix which means half water and best for a single rad d&f. But that's the same with the dealer sold oem Asian LL's like Honda Type2 and the new Nissan LL which are more expensive. The other is the red tint, which matches Toyota AF ok, others not so much. But that is a minor consideration.
As an aside, I've done the multiple distilled d&f (on a Civic) till runs clear or close followed by Honda Type2 d&f's till ~50% concentration, confirmed by 5 an inexpensive 5 ball AF tester. That was after the stealership used original green with a head gasket replacement. Other than leave the o-green in which I wasn't going to do, I had no choice. Took less than two gallons of Type2 to achieve the concentration. The new PepBoys OEM brand LL Asian concentrate would have been ideal in that case. And they make it in all four colors to match the oem AF's and ~$20/gal.
I was wondering if those 3 dollar coolant ball testers really work. I'll pick one of those up for my toolbox.
The ZAF was the coolant of choice I used in my Vibe that turned out to be a Corolla/Matrix clone. I swear at that time of using ZAF it was a full strength. I seem to recall buying distilled water at that time. Now, you cannot locate it full strength. Hmmm.
The Hyundai dealer wants 22 dollars per gallon for coolant plus tax. This is for the non-extended life stuff.
As an aside, the vehicle just underwent a timing belt replacement, but no the water pump as it wasn't recommended to change by the dealer. Would that process have involved changing out coolant?
