Favorite Honda Acura filters
by JeffKeryk - 04/07/20 11:09 AM
Samsung Quitting LCD Business
by SubLGT - 04/07/20 10:59 AM
Moisture inside double pane glass doors.
by Cujet - 04/07/20 09:51 AM
When did mechanics start using rubber gloves?
by atikovi - 04/07/20 09:33 AM
Gearless ratchet
by Farnsworth - 04/07/20 09:22 AM
Troy bilt Zero turn hydrostat fluid?
by racin4ds - 04/07/20 09:20 AM
Bad experience with Monroe strut assembly
by sasilverbullet - 04/07/20 09:16 AM
Hitachi CG22EASSLP
by passgas55 - 04/07/20 09:03 AM
Update: Oil turns dark quickly
by NavyVet88 - 04/07/20 08:48 AM
Do you eat cold pizza or warm it up?
by ZZman - 04/07/20 08:43 AM
This is the turning point...
by Navi - 04/07/20 07:55 AM
accidental fake fraud
by joaks - 04/07/20 07:10 AM
Anyone here try or use Brickell men's shampoo?
by aquariuscsm - 04/07/20 06:49 AM
Adding A Quart for Mustang GT
by ddhmax1973 - 04/07/20 06:29 AM
Victory 106 C.I. filter replaced. . .
by Robster - 04/07/20 06:09 AM
Monaco GP 1992 Senna/Mansell Battle
by IMSA_Racing_Fan - 04/07/20 03:03 AM
RV's for MD's
by 02SE - 04/07/20 01:42 AM
Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
bigboychunky, maleesha2000, baker269, BludRacing, Cacciatore
71119 Registered Users
107 registered members (77GrandPrix, ABerns, 53' Stude, 1978elcamino, 928, 10 invisible), 2,246 guests, and 17 spiders.
Topics303,717
Posts5,240,554
Members71,119
Filter Heat-Sink for ATF Cooling #3622828 02/04/15 05:55 PM
TheLoneRanger Offline OP
How about using one of these for added ATF cooling
with a spin-on filter? If it was mounted in the
airstream, seems like it would add cooling with
filtration all in one.
Some days you eat the bear, some days the bear eats you.....
Re: Filter Heat-Sink for ATF Cooling [Re: TheLoneRanger] #3623213 02/05/15 01:34 AM
DoubleWasp Offline
A transmission cooler will do the same thing, and better.
Re: Filter Heat-Sink for ATF Cooling [Re: TheLoneRanger] #3623247 02/05/15 05:52 AM
SteveSRT8 Offline
Generally if your vehicle really needs cooling a dedicated cooler is fine. Just don't forget the thermostat.
IME just setting up a remote filtration system alone can drop temps several degrees even without cute lil fins...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Filter Heat-Sink for ATF Cooling [Re: TheLoneRanger] #3623655 02/05/15 02:36 PM
B
badtlc Offline
B
that is a terrible design. You'd need a very good thermal paste, most likely an epoxy to get any sort of good thermal contact between the filter housing and the heat sink. The paint on the filter can also presents thermal conductivity problems.
This is the equivalent to a ricer mod. Nothing real can be gained from it other than the sight of it.
2007 Ford Escape XLS 2.3L ATX, M1 AFE 0W20, Fram TG, 167k
2015 Chrysler T&C, 95k+, M1 5W30, Wix OF
2018 Forester Premium 10k+, M1 5W30, EcoGard Syn OF, ST 75W90
Re: Filter Heat-Sink for ATF Cooling [Re: badtlc] #3624255 02/05/15 11:57 PM
I had wondered about the thermal conduction. Looks like it might insulate rather than cool...?
But darn, it would sure look good mounted in the center of the
lower grill opening for all the world to see...
Re: Filter Heat-Sink for ATF Cooling [Re: badtlc] #3625842 02/07/15 04:05 PM
H
HerrStig Offline
H
=1 on the thermal paste. I doubt filter dimensions are exact enough to get the close tolerance necessary for conduction to take place, and too much paste can be as bad as not enough. Nice color, though.
Re: Filter Heat-Sink for ATF Cooling [Re: TheLoneRanger] #3626278 02/08/15 01:05 AM
SuperDave456 Offline
You'd be better off with a remote in line filter with a huge colorful filter. Iincreased capacity and filteration will lower the temps and keep your system much cleaner. If you really wanted to cool things off you could add a true radiator with thermostats and wire in a fan to a controller on the dash. With the in line cooler down stream of it you could increase cooling capacity and volume of fluid.
However this would only be needed on motorhomes and heavy loaded applications.
Re: Filter Heat-Sink for ATF Cooling [Re: TheLoneRanger] #3627964 02/09/15 04:30 PM
dlundblad Offline
I cant see that doing anything whatsoever besides making it easier to spot the filter.
Transmissions have factory coolers which are normally good enough. If the vehicle is used for towing, add an auxiliary cooler.
Adding auxiliary coolers is where I get confused though. Seems like it would be a good idea to add a thermostat so the fluid isnt over cooled, but others seem to recommend putting the cooler before the factory cooler.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Filter Heat-Sink for ATF Cooling [Re: TheLoneRanger] #3628315 02/09/15 10:01 PM
DoubleWasp Offline
Put the cooler after the factory cooler, with no thermostat. This is how the factory does it on applications that come with an auxiliary cooler.
Re: Filter Heat-Sink for ATF Cooling [Re: TheLoneRanger] #3630103 02/11/15 02:09 PM
MolaKule Offline
Global Moderator
Global Moderator
Has anyone seen any data as to how much the temperature is lowered and under what conditions.
Cute, but I doubt it would lower temps.
Dr. Larry Fleinhardt: "You know, that term "dark matter" has always perplexed me. It fallaciously implies that the 95% of our universe that cannot be observed is some amorphous, eventless emptiness."
Amita Ramanujan: "I'm sorry?"
Dr. Larry Fleinhardt: "I guess it's all too human. Instead of admitting to the present limits of our knowledge, we just declare things to be unknowable." NUMB3RS
