When doing oil changes I've seen both technicians and DIYers alike rev the engine right after starting it after an oil change. I assume this is to circulate the oil throughout the engine faster. If you do that aren't you revving an engine with low oil pressure? My natural inclination tells me you shouldn't force it and only rev it once the low oil pressure light goes off. Is it better to idle the engine or to rev it right after changing the oil?
Which brings me to the subject of priming. Is it beneficial to prime oil filters or is it just OCD? Does priming really affect oil pressure on start-up or provide any benefits?
