The OM for our '11 Fusion states that the oil capacity is 5.3 quarts (5 liters) with oil filter. When the Fusion was re-designed for '10, and the 2.5L was first used, the OM stated only 5 quarts capacity. Subsequent revisions of the OM stated 5.3 quarts for the '11 and '12 model years. The motor itself was unchanged, however. The 2.5L is still being used in the '15 Fusion, and was also used in the '13 (first year of re-design) and '14. For those model years, Ford went back to a 5 quart capacity, as specified in the OM. Now, honestly, 0.3 quarts probably won't make a difference in the real world, but which is it? 5.0 or 5.3? I'm hoping we have a Ford service tech on here that has some insight as to why the number has changed back and forth over the years
FWIW, 5.3 quarts does put me just at, if not a mm or so over the full line on the dipstick.
