I own a 1985 Ford F-250 4x4 w/ 460 V8 and 4 speed trans. I rebuilt the Holley 4180C carburetor about a year and a half ago. I've put about 25k on the truck since that time.
Yesterday, I pulled the plugs and all look lean. Pretty grey/white with hardly any combustion deposits; very little carbon like I'm accustomed to seeing on a plug. I can post pics if anyone wants to see them.
Assuming the engine is lean, what should I do with jet size? Stock jet size for this carburetor is a Holley #62, which corresponds to a 0.061" orifice. To account for elevation here (around 6,000 feet above sea level), I went down three sizes as I was told one size for every 2,000 feet elevation. So I'm using #59 (0.058 orifice) at the moment.
Someone once told me that carbs were jetted quite lean from the factory in the 1980's due to tightening emissions regulations and that as emissions became more stringent, they did everything they could to keep carbs on the scene as long as possible (presumably to save money). So supposedly, many engines ran lean by design. Perhaps this is one of them..? Or could I have gone too lean by using a smaller jet to compensate for altitude?
Does anyone have experience sizing jets for Holley carbs? Is running lean even a bad thing? Is there any potential for adding power by richening the mixture? Any help, info, suggestions, etc. on the subject is welcome and greatly appreciated.
