Need a filter for new Tahoe.
Washington
We bought a 2007 Chevy Tahoe last week and the AC Delco filter is a PF48. I can't find an PF 48 anywhere. I've tried some cross-referencing but can't seem to locate another quality filter. Fram and STP are pretty easy to find but not what I want to use.
I'm not real keen on buying one from the dealer either, unless its my only choice.
Any recommendations on a replacement for a PF 48?
Try us for NG/Wix filters.The Wix number is a 57060. The only problem is taht they have not released the filter. This could take a week or a few months. I don't know.
Bryan
What don't you have a several free oil changes with that new Hoe' ?
I did when I bought my 04' ....
Let the dealer do the first few....
After I left for work this afternoon, I came up with the solution.
Buy a PF 48 from the dealer; I know it hurts price wise.
When you get it home, measure the outside diameter of the can.
Then the diameter of the seal.
Then try to figure out the thread diameter and pitch. If you have a hardware store handy, take filter there. they have bolts in all common sizes. If it's a 3/4-16 use that number.
If it's a metric thread, things may be harder.
Most hardware stores might not have a bolt in that large a metric size.
A machine shop might have a thread gauge though.
Reason for this testing is:
it may be a new 'style' filter, not necessarily a new size filter.(it could be both).
Once you find out those sizes, you can use a master catalog that had the filter specs. in the back and find a common filter to cross with.
Given that Fram has such a big part number suggests it's a new style (e-core?)
Good luck.
Neither the Fram or the AC site lists a filter for that truck.
Found this on the WIX site:
Part Number: 57060
Principal Application: Various GM Vehicles (07)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.430
Outer Diameter Top: 2.970
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Max Flow Rate: 10-12 GPM
Gasket Diameters
Number O.D. I.D. Thk.
Attached 1 2.750 2.410 0.270
Purolator lists this part number for their premiumPlus filter: L12222
[ September 19, 2006, 02:25 AM: Message edited by: dwendt44 ]
sometimes the dealer is cheaper than auto parts stores. i got an ac filter for my solstice a $1.75 cheaper than autozone
quote:
Hopefully when Pep Boys starts to carry this filter it'll be the same as their other AC filters. I didn't see one for more than about $5
Alot of times they have coupons for the AC at $2.50 a piece.
quote:
Part Number: 57060
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.430
Gasket Diameters
Where is Wix typically sold?
As this is a new (2007) truck with a new/different filter, the aftermarket suppy channels will take a while to catch up.
The dealer may be the only local source for this filter for a few months.
I called my local AC Delco retailer whom I do business with frequently, PF48 his price is $4+tax. What does a dealer want for it?
quote:
I broke down and bought one from the dealer. I was amazed at how inexspensive it was. I was expecting $10-12 but it was only $5.75.
