Originally Posted By: The Critic
Vacuum bleeding (using mityvac or vacula) has been problematic for me - usually the pedal will be a bit softer after you're finished due to a small amount of air that is let in. I've noticed this on cars that come from other shops that also vacuum bleed.
I don't think it's possible to have any air get in the system, especially via the bleeder valve, as long as you don't let the reservoir empty.
Originally Posted By: volodymyr
Rear wheels are usually accessible without jacking (depends on a car, mine is an SUV so it is easy). Front wheels are accessible if you turn the wheel to expose the caliper.
It isn't possible to gain access to bleeder valves for the S2000 without jack it up.
Originally Posted By: Vikas
Does pressure vs vacuum changes this in anyway?
No, neither method changes the problem of raising the car. What I mean was the actual brake bleeding work with Mityvac is very easy/simple and fast. It was done in less than 10 minutes max, but the time I spent raising the car, remove the wheels, reinstall the wheels and lowering the car was about 1 hour. Too much time and work to prepare for actual job.
I had Motive pressure bleeder some years ago, it didn't work well on my LS400 and E430. I already had the Mityvac to do oil change for my E430, why not use it to do other tasks for all cars such as ATF and brake bleeding ?
I used Mityvac 7201 to bleed the brake systems in all my cars more than once for each car the last 6-7 years. It worked so well for all cars, much better than Motive pressure bleeder.
I rather have 1 tool that can do several jobs well than multiple tools and each tool can only do 1 job.
Originally Posted By: supton
I did this job a month or two ago. Was real easy when I had the car completely on jackstands and doing a tire rotation at the same time too. Remove and inspect pads, lube everything up, change brake fluid, rotate tires, done. Actually I did oil changes at the same time too.
Might as well kill the afternoon and do everything at once.
Do everything all at once is a good idea. Raising the car and removing the wheels and do all maintenance in 1 shot and don't bother with jacking the car up for another 2-3 years.
