P0171 and P0174
by NavyVet88 - 01/26/20 05:04 AM
Essex Engine Plant (Canada)
by BlueOvalFitter - 01/26/20 03:18 AM
Mopar oil bottles
by Franz - 01/26/20 12:47 AM
Ultra-rare barn find!
by Toy4x4 - 01/26/20 12:11 AM
2015 Hyundai Genesis 5.0L Review
by Nick1994 - 01/25/20 11:56 PM
My doggie had a rough week
by Chris142 - 01/25/20 11:26 PM
Delivery meal kit review - Dinnerly vs HelloFresh
by pezzy669 - 01/25/20 10:32 PM
Eotech Vudu scopes
by OVERKILL - 01/25/20 10:10 PM
'12 Civic burning oil after switch to M1
by sr20detfwd - 01/25/20 09:33 PM
Wix/NAPA Gold and M+H
by Uphill_Both_Ways - 01/25/20 09:06 PM
New seafoam oil stabilizer at AZ
by Chesterr - 01/25/20 08:13 PM
In 3 hours - 730 days and counting
by OVERKILL - 01/25/20 08:12 PM
Pig Parker!
by dishdude - 01/25/20 07:58 PM
NGK Conventional vs. Ruthenium Plugs
by doitmyself - 01/25/20 07:58 PM
Container or funnel?
by Philthy_Phil - 01/25/20 07:24 PM
AC Delco filters at Amazon as little as $1.07
by jayjr1105 - 01/25/20 06:22 PM
Excessive moisture in oil
by mb32 - 01/25/20 05:47 PM
Cover for Jeep + Trailer
by kehyler - 01/25/20 05:34 PM
kwashabcp, ronster, BackToReality, Scopeman, M635_Guy
70527 Registered Users
51 registered members (bullwinkle, 2015_PSD, alchargo, BobsArmory, bmod305, blufeb95, 4 invisible), 1,155 guests, and 19 spiders.
Topics300,572
Posts5,178,518
Members70,527
Page 1 of 3 1 2 3
What oil to use for an Aristo 2JZ-GTE VVT-i ? #3545075 11/22/14 12:50 PM
A
afree Offline OP
A
I recently did an Aristo 2JZ-GTE VVT-i engine swap in my IS300. I have been trying to search for some sort of Toyota owners manual to see what the recommended oil for an Aristo but I can't seem to find much.
A little info about the engine fore those who don't know. The engine is from a 1999-2005 Japanese Toyota Aristo, which is similar to the twin turbo Supra engine, but utilizes variable valve timing. I know the Supra specifies API SH 10W-30, but that is for a non-VVT-i engine. The non-turbo version which came in the IS300 (2JZ-GE with VVT-i) is a similar engine and calls for API SL ILSAC 5W-30.
1. What kind of vehicle you have2004 Lexus IS300 with a 2JZ-GTE VVT-i Aristo swapped engine
2. What your owner's manual says -- not just viscosity, but certifications (look for acronyms like API SM, ILSAC GF-4, etc.) and change intervals as well Any info on this would be awesome.
3. Where you live Central Florida
4. How you drive (easy? hard? fast? slow?) All four
5. What your daily drive is like (short trips? long trips? city? highway?) Short trips and highway
6. Whether your car has any known problems None.
Thanks!
2004 Lexus IS300 5-speed 2JZ-GTE VVT-i
2015 Toyota Tacoma Crew Cab TRD Sport 4x4 LB 1GR-FE
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: afree] #3545099 11/22/14 01:16 PM
CATERHAM Offline
I'd suggest a API SL 5W-30 such as the syn blend Quaker State Defy 5W-30 for it's higher anti-wear additive levels. Or a full synthetic such as M1 HM 5W-30.
-'74 Lotus Europa, 5W-50 & VSOT
-'96 BMW 328i, 50/50 TGMO 0W-20/M1 0W-40
-'94 Caterham 7, FUCHS 0W-20
-'18 Tesla Model 3 - FF diff' oil
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: afree] #3545162 11/22/14 02:31 PM
d00df00d Offline
I'm inclined to suggest an ACEA A3 xw-30.
2008 BMW M3 Sedan 6MT
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: afree] #3545172 11/22/14 02:45 PM
T
tinmanSC Offline
T
Toyota did a good job with the oil system on the 2JZ-x engines. The 2Jz-GTE uses a turbocharger water jacket (two of them, actually) as well as a engine oil cooler at the filter. For a turbocharged engine, they are pretty easy on oil and not known for sludge (although to be fair I have seen sludge in these engines from time to time). Really any API-approved oil will be fine. I agree with CATERHAM, SL rated Defy or M1 would be an excellent choice.
Cost of Hobby=2L
(Where L=Cost of Lubricant)
95 Lexus SC300 [email protected], 2000 [email protected] both VML Full Syn+Purolator PSL20195(soon to be Wix)
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: tinmanSC] #3545177 11/22/14 02:58 PM
J
Jeffs2006EvoIX Offline
J
I think a heavy 30w would be great for this or a light 40w.
So with that in mind Redline 5w30 sounds great for this app, or M1 0w40 that you can buy right off the shelf at most stores.
If your car is going to stay bone stock and no power upgrades or boost being cranked up, I agree with CATERHAM, but if you went through all the work of swapping in a Turbo version of this engine, I think mods are coming. I stand by my choices, modded or not.
Just my ten cents... drive
Jeff
"You don't have to be crazy to do this... But it helps." Bob Ross.
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: tinmanSC] #3545189 11/22/14 03:16 PM
d00df00d Offline
If this is true, consider my suggestion changed to plain-Jane Mobil 1 5w-30. :]
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: afree] #3545216 11/22/14 03:40 PM
A
afree Offline OP
A
Sorry, I should have stated that the twins have been replaced with a single turbo (no water cooling) pushing only 10 psi smile
Since its a fresh swap, I just used M1 10W-30 to get it fired up. Looks like I may switch to M1 5w-30. Also using a factory Toyota filter.
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: afree] #3545227 11/22/14 03:52 PM
d00df00d Offline
Ah, okay.
Back to an ACEA A3 xw-30 for me!
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: d00df00d] #3545233 11/22/14 04:00 PM
A
afree Offline OP
A
Originally Posted By: d00df00d
Ah, okay.
Any suggestions on ACEA A3 oils? Would GC be too thin for this engine/my location?
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: afree] #3545287 11/22/14 05:05 PM
d00df00d Offline
GC was one of the oils I had in mind. :]
When you're thinking about "thick" or "thin," what you really want to look at is HTHS viscosity, which isn't part of the viscosity grade. ACEA A3 means it has to be at least 3.5, which is higher than almost all xw-30s you'll find on the shelf. Anything labeled A1 or A5 has to be LESS than 3.5.
Also, keep in mind that the second number (30) matters a lot more than the first one (0w, 5w, etc.). The W number is just a cold pumpability number and doesn't say much about "thick" vs. "thin," except at the coldest temps.
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: afree] #3545291 11/22/14 05:07 PM
A
aa1986 Offline
A
Mobil's German website suggests Newlife 0w40 or Super 3000 X1 Formula FE 5w30 for all Japanese model Aristo's.
I'd go with the M1 0w40.
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: afree] #3545403 11/22/14 06:55 PM
A
afree Offline OP
A
Good find thanks.
I'm thinking of either going with GC or Amsoil 5W-30
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: afree] #3545921 11/23/14 12:59 PM
A
afree Offline OP
A
Would cold starts in Florida have any issues with the GC?
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: afree] #3545960 11/23/14 02:05 PM
O
Oro_O Offline
O
Our plain-breathing 2JZ really liked M1 5w-30 HM (what Caterham mentioned above). Toyota chart says to use 5w-30 or 5w-20 in the last us year Supras.
Totota Oil Chart
Interesting swap. I have always wanted to drive a twin-turbo 2JZ-GTE with the VVT-i, having been impressed with what it did to the 1MZ-FE I have driven in both versions. Did any ever get imported here, or are these all engine imports only? Supra turbo is very much a possible buy for me in a few years, a VVT-i one would be a dream.
Re: What oil to use for an Aristo 2JZ-GTE VVT-i ? [Re: afree] #3546172 11/23/14 05:55 PM
A
afree Offline OP
A
Thanks for the chart. Yea I have seen quite a few shipped over here (none in person, just being sold on Craigslist). I guess its easier than say, a Skyline since you could probably register it as a GS300/400. I have even seen a few of the 1998+ Supras with the VVT-i. Its a great engine. If only we had them in our cars over here already.
Page 1 of 3 1 2 3
