I'm looking at two Napa batteries, but I can't quite figure out the actual construction difference aside from the obvious warranty difference.
Napa Legend 7559
(75 month warranty, group 59 size)
CCA: 590
CA: 700
Weight: 37 lbs.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=NBP7559_0398897352
Napa Legend Premium 8458
(84 month warranty, group 58 size)
CCA: 580
CA: 725
Weight: 28lbs.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=NBP8458_0398897353
They are different group sizes, but the dimensions are very close. I can't see where the nearly 10 lb. weight difference comes from. Both are normal lead acid batteries. I believe both are JCI batteries, as Napa carries Optima too.
I'm kind of leaning towards the 8458, but the 7559 has better availability.
Any thoughts on the weight difference?
Napa Legend 7559
CCA: 590
CA: 700
Weight: 37 lbs.
CCA: 580
CA: 725
Weight: 28lbs.
