The doors on my 2006 Pontiac Grand Prix will no longer lock using either door switch or the keyless entry remote. Pushing the switch to "lock" or pressing the lock button on the remote will result in a single click in the dash, but the door locks will not engage, but the alarm will arm. I have the auto lock setting (where the doors lock when you begin to drive away) active, but they do not lock then either. The door switches and remote will still unlock the doors and pop the trunk (by holding it in the "unlock" position), turning my power door lock feature in a power unlock only feature.
I have checked the door lock fuse and it is intact. I deactivated the door lock delay feature (if you press the door switch to "lock" a single time, a chime sounds, and the door does not lock for a few seconds) through the DIC and the doors locked the next time I pressed the switch! I then unlocked the doors and tried to lock them again, but with no luck. I reactivated the door lock delay feature and tried again, with no success, and then deactivated it again, but it will not repeat its one-time lock trick.
This is an inconvenience that I can deal with, but it gets tiresome when I have to pop the trunk using the door switch (my wife has our only remote), manually lock each door from the inside, and then lock and close the drivers door.
Can anyone shed light on what may be going on and what can be done to fix it? I have done some Googling on the matter and nobody seems to be able to fix this issue with GM door locks, not even the dealerships. Could this be related to the ignition cylinder issues resulting in the recall?
Edit: This started out as an intermittent problem a month or two ago but now seems here to stay. I would blame it on the weather getting cold, but we are still getting into the 80s and 90s here.
