Originally Posted By: Trav
Originally Posted By: CATERHAM
I suspect 0W-20 is specified along with the option of some heavier grades which is a common pattern in Europe.
Oh i see, so you admit there might be a situation to use the higher viscosity oil.
If that was the case you just made my point. It obviously means the engine requires higher viscosity when operated at high speeds.
Just like the Subaru manuals did in the US. You are trying to promote a product for uses it was never intended for.
Telling a guy in Australia to track his car on TGMO is reckless at best.
First for the record it should be noted you have expressed in the past an abject fear of 20 grade oils for any sort of perceived demanding use. When I informed you a while back that Porsche ran the Fuchs 0W-20 in the GT3 Porsche Cup series successfully a few years ago you refused to believe me.
Yes I can see a use for a heavier than necessary oil under certain conditions such high oil consumption which constant cruising at high rpms could contribute to. Or if availability of the recommended grade is a problem.
But make no mistake the lightest oil recommended is all that's required to satisfy the lubrication demands of the engine under all conditions.
I am not recommending the 0W-20 grade, Toyota/Subaru are and there is absolutely no requirement to run anything heavier. This
is a sporty little car and it's totally naive to believe that the manufacturer hasn't accounted for extreme use in their oil grade recommendation and track results have proven this to be case. I haven't heard of a single case of the spec' oil grade failing to do it's job.
To give another example of where the 20 grade is recommended for track use is the Ford Mustang GT with 430hp. A 5W-20 semi-synthetic is the spec' oil and Ford specifically is on record stating that nothing heavier is required even for track day use. Like the Toyota 86 and it's clones, the Mustang GT does
not come with an oil cooler and if oil temp's get too high the electronic management safeties will kick-in. If this happens too often Ford recommends installing the optional oil cooler, not a
heavier oil grade which if anything is counter-productive.
