Originally Posted By: thorromig
New Monroe Struts all the way around, new engine mounts replaced in 2012, new iridium spark plugs last year, new serpentine belt replaced in 2011, oil changed every 5000 miles with Pennzoil High Milage until my takeover, new air & cabin filter replaced in 2014, tranny fluid drained & replaced in 2014. New brakes replaced all the way around in 2012, techron fuel injector cleaner ran at the end of the last couple oil changes. Car has had its routine maintnance done since new. I will more than likely keep the Camry at least for another 2 years I have decided. Till then I can save more dimes and go from there. Also just put new tires all the way around and that was $700.00 skins.
By all means, keep it!
My '04 Accord is at 141k and runs like a top. I will be very disappointed if anything major fails before 250k.
