Question about stored vehicles
by loneryder - 11/22/19 12:53 PM
Camry exhaust downpipe
by supton - 11/22/19 12:30 PM
What is your favorite airline and why?
by ZZman - 11/22/19 11:35 AM
Costco Instant rebate for M1
by Joephu - 11/22/19 11:25 AM
Serpentine belt
by Grambo - 11/22/19 10:50 AM
My 2016 Ford Fiesta Failure
by Mr_Luke - 11/22/19 10:37 AM
Starter Tool set - hand tools for professional work?
by btanchors - 11/22/19 10:20 AM
Acceptable amount of time to get up to speed?
by ls1mike - 11/22/19 09:35 AM
Paint question
by supton - 11/22/19 09:31 AM
SUV tires vs passenger car tires
by Ded Mazai - 11/22/19 09:00 AM
Crysler Crossfire Pro/Con?
by tc1446 - 11/22/19 08:54 AM
Possible to balance a bent steel wheel?
by johnnyh55 - 11/22/19 06:33 AM
Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
hunter9296, Corslayth, oildud, Kylefl1, JDee71
69938 Registered Users
111 registered members (alteredtuning990, bdcardinal, avi1777, BAJA_05, askani79705, 2015_PSD, 9 invisible), 2,466 guests, and 24 spiders.
Topics297,778
Posts5,122,362
Members69,938
Most Online3,589
Nov 2nd, 2019
Rate Thread
Replacing Valve Stem Seals, Honda or Aftermarket? #3520208 10/24/14 01:28 PM
Z
zpinch Offline OP
Z
I need to replace my valve stem seals in my Honda CRV, I already bought some aftermarket Viton units.. but now I read somewhere that the intake and exhaust valve stems are slightly different size and that's why Honda have INTAKE seals and EXHAUST seals. The seals that I purchased are blue Viton, 16 in a bag all the same.
Does anyone hear have good knowledge on K24 engines that can say whether these seals will 'seal' as well as Genuine Honda?
Thanks.
2003 Honda CRV w/217,000km
AMSOIL remote bypass filter (EAO15 & BP90) & EAA
Signature Series AZO 0w30 - 41,000km+ on bypass unit/oil
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: zpinch] #3520226 10/24/14 01:44 PM
H
Hokiefyd Offline
H
What is the cost difference? My default for something like this is always OEM parts, unless there's a compelling reason to not go that route.
How many miles are on this engine?
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: zpinch] #3520258 10/24/14 02:11 PM
CT8 Offline
Being a retired service tech I would talk to a good engine machine shop . Sometimes aftermarket part may be upgraded over oem Sometimes not.
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: zpinch] #3520302 10/24/14 03:00 PM
1
19jacobob93 Offline
1
After market all the way when it comes to valve seals in [censored] engines.
We rebuilt a Mitsubishi 3.5 v6 because it left a smoke screen wherever we went! They start smoking very early on because the valve stem seals they use dry up easily and if we used OEM ones we would be back to square one by now, so we used a well known after market brand which i don't know the name of. After 5 years and 150,000km since the overhaul it doesn't use a drop of oil or smoke a single bit
2000 Ford Falcon AU2 (t-boned @350k, now used as a tractor!)
1998 BMW 316i Compact (Blown head gasket @150k)
2019 Hyundai Accent
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: zpinch] #3520394 10/24/14 04:50 PM
P
PandaBear Offline
P
I'd be very surprised if they are "slightly different size" and aftermarket vendors just choose to use one size fits all. The usual case is they are made to withstand different temperature and one size fits all means they are all exhaust temperature grade.
What is the OEM material made out of? Viton should be a very good material for valve stem seals.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: Hokiefyd] #3520565 10/24/14 08:32 PM
Z
zpinch Offline OP
Z
The cost difference is the same... $15 to $30 for the same aftermarket seals, or Honda units for $30, and only the exhaust seals are made from Viton.
I have 190,000 km now, and 171,000 km when i bought it in March of this year, a 2003 Honda CRV. So I think it's more the age than the mileage for seals like this. It's when I started using synthetic oil when they started leaking... they must have been slightly plugged up with debris around the valve stem, I don't know, but now they are not sealing.
I have found I think all the tools I need to do the job, valve seal remover tool, valve keeper tool, and a torque wrench, all on Amazon.ca for less than $150.
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: 19jacobob93] #3520568 10/24/14 08:34 PM
Z
zpinch Offline OP
Z
You telling me this, makes me feel good about doing this. I want a good result afterwards. I am sometimes getting like a rapping or knocking noise when more short trips are done as the oil consumption goes up and I think it's fouling the plugs, and building up oil ash inside...
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: PandaBear] #3520571 10/24/14 08:36 PM
Z
zpinch Offline OP
Z
These aftermarkets are 'supposed' to have a tighter fit with them having stronger springs on the neck of the seal.
Running a bypass filter setup should prevent this from ever happening again.
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: zpinch] #3520718 10/25/14 01:14 AM
B
berniedd Offline
B
Use Honda parts. I used aftermarket valve seals in my CRV as part of a cyl head reconditioning job a few years ago, and in 10,000 miles they were leaking again.
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: zpinch] #3521010 10/25/14 01:04 PM
Z
zpinch Offline OP
Z
Berniedd, exactly what brand were these seals and where did you get them?
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: zpinch] #3521034 10/25/14 01:42 PM
Yah-Tah-Hey Offline
Perfect Circle teflon oil seals.
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: zpinch] #3521072 10/25/14 02:40 PM
G
Gokhan Offline
G
Given that changing the valve seals is such a time-consuming and difficult job, I'm guessing you didn't opt for aftermarket parts just to save $10 bucks of the total cost of repair.
Since the OEM parts are different, there is probably a reason, the reason most likely being to provide appropriate oil metering, as the oil suction on intake and exhaust valve guides is different.
For the peace of mind and correct oil metering, I would go with the OEM parts, especially given that the aftermarket part seems to have the incorrect oil metering on either the intake or exhaust, perhaps both.
https://estore.honda.com/honda/parts/vie...E++1010&dl=
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 1,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: zpinch] #3522258 10/27/14 01:35 AM
B
berniedd Offline
B
It's been years since then, and I don't recall the exact brand, but they were not any of the big name aftermarket jobbers. Go with Honda, you can't go wrong there. They are not that expensive either.
Re: Replacing Valve Stem Seals, Honda or Aftermarket? [Re: zpinch] #3522330 10/27/14 06:20 AM
T
The_Eric Online Content
Online Content
T
I think you answered your self as to why the OE parts have two different numbers- I'd also be surprised that the valve stems are two different diameters.
Either way you can't go wrong- as long as you don't go with NON name brand aftermarket stuff. Perfect circle or Fel-Pro for example.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
