Originally Posted By: Bloodknights
wow then please educated me on this,i never knew a motor oil designed to be a 20 grade is thinker then a 20 weight when its cold????.....whatever, use 5w20 no harm will be done to your engine ,there both 20 grade when your driving down the road at the end of the day.for those saying your going to lose your warranty for using a 5w instead of a 0w is misleading,the fact is just starting up your engine and going down the block it no longer is a 0w anymore as the temp on the oil rises, cuz common sense says from a 0w it starts going up in grade to reach its goal of a w20 ,sooo as your driving it goes from a 0w,to a 5w,to a 10w etc till it reaches w20, just use what you like and lets use common sense no harm will come to your engine with 5w20.your never going to get a straight answer cuz everyone here has there own opinion and think they are right.
0w, 5w, 20wt, 30wt, etc are classifications, not the viscosity. To be labeled say, a 5w-30, an oil's flow characteristics must fall within a specific range at certain temps. This article explains it in detail.
http://www.bobistheoilguy.com/putting-the-simple-back-into-viscosity/
