I've never seen a 0w20 oil with higher than ~0.85 g/cm3 density. Even much heavier synthetic oils are all around the 0.86g/cm3 area. Is this higher density a good thing? Does it mean that it uses less VI additives? How does this affect HT/HS vis?
The previous API SM high VI version of Idemitsu 0w20 only had a density of 0.84 g/cm3 but had a VI of 197: http://www.worldpac.com/tagged/IDEMITSU_Motor_Oil_0W20.pdf
