Originally Posted By: SilverC6
Is the factory fill still Mobil 1?
Why yes, I do believe the factory fill in that Corvette was Mobil 1.
Originally Posted By: mobiloil.com
Chevrolet factory fills every Corvette with Mobil 1 5W-30,
Originally Posted By: aquariuscsm
They're saying bad oil filter,and that a piece of metal was allowed through the filter,BUT,where did that piece of metal come from,and what made it break loose from the internals to be able to reach the oil filter? I call b.s. on blaming the oil filter.
Should GM step up to a 50 weight on their highest performance car like Ford?
Originally Posted By: dlundblad
How is this the oil filters fault?
What was said metal particle doing in the oil anyways? Something had a problem.
Agreed. The filter thing is a red herring. The filter circuit has a bypass which can open quite easily in normal operations.
The problem is the 'metal chunks'.
No question they were beating on it, but that's entirely in their jurisdiction to do so. They weren't abusing it by neglecting prescribed maintenance, though it may have ran low on oil and someone failed to catch it in time. Again, can't imagine that happening with the computer crying about low oil for so long.
Also, what are the chances that the one defective build vehicle makes it directly to the journalists? It's much more likely that if defect is involved, that it's s design or specification defect. Even assuming that
1 in 10 Corvettes are defective in materials or workmanship (outrageous), that's still an unlikely chance that the journalists would end up with that one.
What else could it be?...
