Champion generator with remote start
by Vikas. 11/17/18 12:58 PM
Autozone clearance has started!
by jasonal. 11/17/18 12:49 PM
Midgrade 89 Octane ?
by Kjmack. 11/17/18 11:54 AM
$0 medicare advantage plans??
by danez_yoda. 11/17/18 11:53 AM
Jack Lalanne
by CourierDriver. 11/17/18 11:38 AM
2015 Chrysler T&C Slow To Warm
by badtlc. 11/17/18 11:30 AM
9 mm or .22? I'm torn.
by Eosyn. 11/17/18 11:15 AM
Blower motor recommendations
by 53' Stude. 11/17/18 11:12 AM
Amsoil CVT
by ARB1977. 11/17/18 11:05 AM
Weird Battery Failure.
by George7941. 11/17/18 10:35 AM
Pro-Max Syn Oil 5w30..5qt for $18.65
by Warstud. 11/17/18 10:32 AM
Recommend a workhorse "no frills" snowblower
by Audios. 11/17/18 09:50 AM
Douglas Tires anyone?
by Carbon12. 11/17/18 09:37 AM
Cummins QSB oil viscosity recommendations
by jrmason. 11/17/18 09:29 AM
Easy walking
by CourierDriver. 11/17/18 09:22 AM
Rain-x Wiper Blades
by Snagglefoot. 11/17/18 09:09 AM
How long does Stabil last?
by Audios. 11/17/18 08:09 AM
Lubrication of Chop Saws
by Snagglefoot. 11/17/18 07:58 AM
portypota, babake, messenger300, Sammeh, Dan6074
66454 Registered Users
76 registered members (another Todd, Audios, beanoil, bdcardinal, 12 invisible), 2,268 guests, and 33 spiders.
Topics293,643
Posts4,902,055
Members66,454
Most Online2,553
Oct 27th, 2018
Odometer says "Error" - 2008 Jeep Liberty #3472152
09/02/14 06:21 PM
09/02/14 06:21 PM
Lehigh Valley, PA
Ranger1 Offline OP
Ranger1  Offline OP
Lehigh Valley, PA
Hello all,
After cleaning some acid / corrosion of a negative battery terminal, I reconnected my battery cables to the battery. Now my odometer says 'Error' all the time. Otherwise, my 2008 Liberty runs fine.
Has anyone run into this issue on a Jeep? Does anyone know why this happened? And better yet, how do you fix this?
Thank you.
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3472174
09/02/14 06:31 PM
09/02/14 06:31 PM
Mahzurrah!
KCJeep Offline
KCJeep  Offline
Mahzurrah!
You can try the turn-key-codes procedure to see if it will reset. If you are not familiar with it, turn the key on then back off three times within 5 seconds, just far enough to turn everything on without actually engaging the starter. The last time you turn it off it should give you codes, or in your case maybe it will reset.
If that doesn't work I'd try disconnecting the battery again for over 30 minutes before reconnecting it.
If that doesn't work the Liberty Forum on Jeep Forum should be able to help you.
2018 VW Passat GT VR6 - New FF
12 KIA Sedona 92k - PP HM 10w30
09 Ford Focus 131k - Supertech FS HM 5w30
00 Chev Lumina 203k - Supertech FS HM 5w30
04 Jeep Grand Cherokee gone but not forgotten.
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3472190
09/02/14 06:38 PM
09/02/14 06:38 PM
Lehigh Valley, PA
Ranger1 Offline OP
Ranger1  Offline OP
Lehigh Valley, PA
KCJeep... OK. I tried your key trick, but nothing happened. Previously, I tried disconnecting the battery for a full hour, which also did not work.
Also, I tried pushing-in the Trip Odometer button for several seconds. This did show me the labels for "Var 1" thru "Var 15", but I did not see any corresponding values. (Not sure what to do to view them.) Plus, I do not have a decoder book to tell me what they would mean either.
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3472245
09/02/14 07:12 PM
09/02/14 07:12 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Next time, you may want to try holding the + and - battery terminals together to drain the power from the system, while both are disconnected from the battery.
Do you have the owner's manual? If not, you can download here: http://www.jeep.com/en/owners/manuals/
Edit: after looking at the owner's manual, if the power drain doesn't work, I don't know...dealer may be involved. Did you do anything in addition to cleaning the battery terminals? Did water enter anything under the hood?
Thick vs Thin test: 15k / 43k miles complete
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3472267
09/02/14 07:19 PM
09/02/14 07:19 PM
NE
VNTS Offline
VNTS  Offline
NE
Disconnect the battery again, leave it off for 10 minutes, reconnect and see what happens.
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3472283
09/02/14 07:25 PM
09/02/14 07:25 PM
Lehigh Valley, PA
Ranger1 Offline OP
Ranger1  Offline OP
Lehigh Valley, PA
I have had the battery disconnected a few times now. The longest time being for an hour. And so far, nothing has changed. It still says 'Error'.
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3472427
09/02/14 09:00 PM
09/02/14 09:00 PM
FEMA Region 4
jk_636 Offline
jk_636  Offline
FEMA Region 4
Do you have a good scan tool? And if so does it throw any codes?
2006 Dodge Ram 1500 4.7 (Supertech 5w30 + OCOD)
2012 Ford Escape 3.0 (Royal Purple 0w20 + Fram Ultra)
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3472438
09/02/14 09:06 PM
09/02/14 09:06 PM
CT
hattaresguy Offline
hattaresguy  Offline
CT
Nice, drive it for 3-4 years than fix it...
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3472518
09/02/14 10:13 PM
09/02/14 10:13 PM
Massachusetts
babbittd Offline
babbittd  Offline
Massachusetts
This seems to be fairly common problem with Jeeps
these might help. a lot of talk about dealers "flashing" the PCM.
http://www.lostjeeps.com/forum/phpBB3/viewtopic.php?f=88&t=77042
http://www.lostjeeps.com/forum/phpBB3/viewtopic.php?f=88&t=71955
http://www.jeepforum.com/forum/f292/error-odometer-spot-1387217/
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3472540
09/02/14 10:42 PM
09/02/14 10:42 PM
Lehigh Valley, PA
Ranger1 Offline OP
Ranger1  Offline OP
Lehigh Valley, PA
Well, my Jeep was fine before I cleaned the battery terminal. Hopefully, the re-flashing of the PCM will solve it. But, since I do not have a scanner/programmer tool, and it seems like you need the right one to do it, then it looks like I need to go to the dealer.
I will post my results from the Dealer, likely in another day or two.
Or, if anyone comes across other solutions that worked, please let me know.
Thanks everyone.
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3473329
09/03/14 08:12 PM
09/03/14 08:12 PM
FEMA Region 4
jk_636 Offline
jk_636  Offline
FEMA Region 4
By your own professional grade scan tool. They aren't that expensive and you will use it a lot more often than you think. One of the best tools (if not the best) I have ever bought.
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3473641
09/04/14 06:47 AM
09/04/14 06:47 AM
Onondaga County
Miller88 Offline
Miller88  Offline
Onondaga County
Only Chrysler ... That's worse than some cars disabling the radio.
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3490528
09/22/14 08:08 PM
09/22/14 08:08 PM
Lehigh Valley, PA
Ranger1 Offline OP
Ranger1  Offline OP
Lehigh Valley, PA
Hello again. Well, it took me a bit longer until I could get to the dealer, but I got it fixed now.
Yup... they needed to reprogram the PCM.... for $62.
One interesting note... The mileage read exactly where it left off at. So, I now have a few extra miles on it that aren't on the odometer.
They did mention there were some other software updates available for the computers, but I would have to pay for them too. (Not interested right now.) But, they did say one of them may help a lag when shifting around 45 mph.
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Ranger1] #3491113
09/23/14 10:39 AM
09/23/14 10:39 AM
NY
BIGJ552000 Offline
BIGJ552000  Offline
NY
Wow.....looks like we are going down a very dark path with car manufacturers. Now we have to pay for software updates that they originally caused these issues SHOULD take care of it for free in the first place. Especially when it had to do with safety or in this case mileage where on a title you have to state that the mileage is true and correct. But with dodge, chrysler products you really never know. Well buyer beware!
Re: Odometer says "Error" - 2008 Jeep Liberty [Re: Miller88] #3491144
09/23/14 11:01 AM
09/23/14 11:01 AM
MI
doitmyself Offline
doitmyself  Offline
MI
But not even close to a car that applies it's brakes by itself (no foot on the pedal) due to electronic glitches: http://money.cnn.com/2013/03/14/autos/honda-acura-recall/
