Rotella 10W40
by jakewells
06/19/18 10:43 AM
Extend WiFi Range at the Laptop?
by clarkflower
06/19/18 10:40 AM
Silicone containing waxes
by mjoekingz28
06/19/18 09:44 AM
Matrix totaled
by circuitsmith
06/19/18 08:32 AM
Door rust problems
by Dave Sherman
06/19/18 07:51 AM
2016 Honda Civic problems
by dbias
06/19/18 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
06/19/18 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
06/19/18 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
06/19/18 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
06/19/18 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
06/19/18 05:44 AM
better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
86 registered (Andy636, ArrestMeRedZ, 853okg, 2strokeNorthstar, 2015_PSD, 8 invisible), 1620 Guests and 43 Spiders online.
65265 Members
67 Forums
285589 Topics
Page 1 of 2 1 2 >
#3467799 - 08/28/14 07:36 PM Non detergent oil for air compressors?
SnowDrifter Offline
Loc: WA
So, as I understand it: Non detergent oil is used in air compressors because the moisture will settle to the bottom of the drain vs. emulsifying. Seems to make sense to me.
Now, here's the confusion. My compressor, a Kobalt 30 gallon compressor, has a sticker on the side that says non-detergent oil. In the product manual, it specs out either Kobalt's own oil, or Mobil 1 synthetic 10w-30.
So... This begs the question: Why would they recommend a passenger car oil while warning of "regular automotive oils" in the user manual? It still doesn't add up with the non-detergent oil labeling on the side.
What's different about Mobil 1 in this application?
#3467833 - 08/28/14 07:58 PM Re: Non detergent oil for air compressors? [Re: SnowDrifter]
zzyzzx Online   sleepy
Loc: Baltimore, Maryland, USA
Walmart sells non detergent oil by the quart in it's motor oil section. Way cheaper than then little bottles in the air compressor area.
#3467834 - 08/28/14 07:59 PM Re: Non detergent oil for air compressors? [Re: SnowDrifter]
jrustles Offline
Loc: Ontario, Canada
Your compressor was engineered using Mobil 1 engine oil, the world's leading #1 synthetic oil. Tests have shown that more compressors run on Mobil 1 engine oil have their serviceable life extended two to seventy times vs compressors running the next leading synthetic oil. wink
"No matter how paranoid or conspiracy-minded you are, what the government is actually doing is worse than you imagine" W.Blum
#3467865 - 08/28/14 08:19 PM Re: Non detergent oil for air compressors? [Re: SnowDrifter]
Chris142 Online   content
Loc: Deplorable in apple valley, ca
the ch compressor i used to have said to use 10w40 engine oil in it.go figure
Edited by Chris142 (08/28/14 08:20 PM)
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#3467899 - 08/28/14 09:01 PM Re: Non detergent oil for air compressors? [Re: SnowDrifter]
901Memphis Offline
Loc: Northern Kentucky
If the compressor allows for the synthetic 10w30, i would run it. I think they run forever on anything as long as it doesn't run dry!
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
#3467960 - 08/28/14 10:22 PM Re: Non detergent oil for air compressors? [Re: SnowDrifter]
Trav Offline
Loc: MA, Mittelfranken.de
When i bought the Quincy the service guy told me it only needs the most basic oil, the additives found in engine oils are of no benefit to it.
On the other hand he didn't say those additives would harm it either, i cant see how it would either but i deferred to their recommendation.
#3467967 - 08/28/14 10:32 PM Re: Non detergent oil for air compressors? [Re: zzyzzx]
Cristobal Offline
Loc: In The Region Between
Accel is the non-detergent oil I commonly see at Walmart.
Surrounded by ferocious, snarling, & spoiled Poodles!
#3467969 - 08/28/14 10:36 PM Re: Non detergent oil for air compressors? [Re: SnowDrifter]
joegreen Offline
Loc: NY
I use 30wt nd napa brand oil from napa. Its cheap and i have run my compressor hard and hot and the oil has never failed.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
#3467970 - 08/28/14 10:37 PM Re: Non detergent oil for air compressors? [Re: jrustles]
Clevy Offline
Loc: Saskatoon canada
You can't be serious.
OP
I've got 16 5.5hp Honda powered air compressors. I've NEVER used a detergent oil in them. I use only amsoil compressor oil because of the conditions these pumps operate in.
From 30c to -40c we are working and amsoil stays fluid at those cold temps.
The engines get supertech because I need 5 gallon pails because I've got so many compressors to service.
Use only non-detergent oil in the pump. I've seen guys use regular oil and the stuff foams up once any moisture gets in the oil. Foam isn't a good lubricator.
2006 Charger RT
Miles x 2 per oil filter
#3467993 - 08/28/14 11:05 PM Re: Non detergent oil for air compressors? [Re: SnowDrifter]
bubbatime Offline
Loc: South Florida
Detergent oils will foam up when agitated. Foam doesn't lubricate very well, and is why non-detergent oil is recommended.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
#3468014 - 08/28/14 11:23 PM Re: Non detergent oil for air compressors? [Re: SnowDrifter]
SnowDrifter Offline
Loc: WA
^^Makes sense. But I still don't understand why they say non-detergent and Mobil 1 in the same breath
#3468036 - 08/28/14 11:50 PM Re: Non detergent oil for air compressors? [Re: Trav]
JHZR2 Offline
Loc: New Jersey
I can understand that angle - only an "R&O" add pack is needed/desired because of the basis of operation. The fact that the detergents are the means of emulsifying water in the oil is news to me.
#3469136 - 08/30/14 09:41 AM Re: Non detergent oil for air compressors? [Re: SnowDrifter]
Donald Offline
Loc: Upstate NY
I am on a 25 yr compressor oil change cycle. I changed it this year and last time was in the 1980s (give or take), actually that was when it was new. Its 5HP two stage that does not see a while lot of use.
The issue is I am 61 and thus the next oil change will be when I am 86.
2015 Ford F250 w/Powerstroke
#3469138 - 08/30/14 09:45 AM Re: Non detergent oil for air compressors? [Re: JHZR2]
Donald Offline
Loc: Upstate NY
I am not sure what the additive is or what oil has it, but Mercruiser gear oil has an additive to hold water with the gear oil and not let it settle out. I believe it just holds it in suspension. Not being a chemist, I am not sure of the difference between emulsify and suspension. Darn another question my Dad could answer. I miss him.
#4453245 - 07/08/17 10:20 AM Re: Non detergent oil for air compressors? [Re: bubbatime]
ArcticDriver Offline
Loc: USA
Sorry for creating a zombie thread.
How does the action of a compressor "agitate" oil and that of an internal combustion engine NOT agitate oil?
I must be misunderstanding something.
Don't motor oils have anti-foaming additives?
Multiple Diesel and Gasoline vehicles
Page 1 of 2 1 2 >
