Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
81 registered members (Artem, Audios, 4WD, amblerman, ammowaster, 15 invisible), 2,142 guests, and 39 spiders.
Topics295,106
Posts4,927,905
Members66,688
Most Online2,553
Oct 27th, 2018
FRAM TG3614 and WIX 51348 cut open #3463216
08/23/14 04:19 PM
08/23/14 04:19 PM
TN
HX520W Offline OP
HX520W  Offline OP
TN
The WIX was installed on a 2008 Dodge grand caravan 3.8L on October 1st 2013 and was in service for 4100 miles until August 12th 2014. I have no complaints about the construction of this filter. In use however it did cause loud lifter noise on start up. (Start up noise was fixed by going back to a FRAM TG.)
The FRAM was installed on a 1997 Saturn sl1 that previously didn't have an oil change for 11k miles and didn't have a filter change for 17k (previous filter was a NAPA pro select which tore in four places). The filter was installed on April 4th 2014 and was in service for 3100 miles until August 22nd 2014. I have one possible complaint about the construction of this filter (see second to last picture). In use I'm very happy with how this filter performed. Even with how dirty the engine is it took weeks before the oil became dark enough to get a good reading on the dipstick.
Side with the seam in the media
Side opposite the seam
Maybe Motorking can explain this to me. I cut open one other TG3614 before this one and it had a metal crimp where both ends of the media meet. Was there a design change or was this filter somehow skipped during manufacturing?
^^Note all the junk between the pleats.^^
This is how much junk the FRAM captured in two pleats eek.
Re: FRAM TG3614 and WIX 51348 cut open [Re: HX520W] #3463228
08/23/14 04:47 PM
08/23/14 04:47 PM
FEMA Region 4
jk_636 Offline
jk_636  Offline
FEMA Region 4
The Wix looks like it held up well. Nice straight pleats, plenty of thick filter media and those beautiful metal end caps! grin2 As for the tough gaurd, Im not really a fan, so I couldn't comment without bias. The only Fram I would personally feel good about using would be the Ultra. Those things are built like tanks!
2006 Dodge Ram 1500 4.7 (Supertech 5w30 + OCOD)
2012 Ford Escape 3.0 (Royal Purple 0w20 + Fram Ultra)
Re: FRAM TG3614 and WIX 51348 cut open [Re: jk_636] #3463232
08/23/14 04:54 PM
08/23/14 04:54 PM
South
JDW Offline
JDW  Offline
South
X2 wink
Ford's & Wix filter's Amsoil 5W-30 SS
2014 Wix Master Tech
Re: FRAM TG3614 and WIX 51348 cut open [Re: HX520W] #3463271
08/23/14 06:17 PM
08/23/14 06:17 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
Nothing like having the best built filter, and the cheapest looking filter, side by side.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: FRAM TG3614 and WIX 51348 cut open [Re: HX520W] #3463277
08/23/14 06:23 PM
08/23/14 06:23 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
The Tough Guard is superior to the Wix no matter what you might "feel" the efficiency is higher and it obviously catches more contaimination than the Wix which is a lower efficiency filter.
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
Re: FRAM TG3614 and WIX 51348 cut open [Re: 901Memphis] #3463283
08/23/14 06:36 PM
08/23/14 06:36 PM
FEMA Region 4
jk_636 Offline
jk_636  Offline
FEMA Region 4
Originally Posted By: 901Memphis
The Tough Guard...it obviously catches more contaimination than the Wix which is a lower efficiency filter.
Obviously these filters were on two different vehicles...so perhaps not the best example of why one is superior over the other. I think that the construction differences between the two speaks volumes more.
Re: FRAM TG3614 and WIX 51348 cut open [Re: HX520W] #3463295
08/23/14 06:57 PM
08/23/14 06:57 PM
Ontario, Canada
jrustles Offline
jrustles  Offline
Ontario, Canada
Wow that Fram just exudes build quality, especially compared to that sloppy Wix. Man, next time I'm gettin' a Fram!
"No matter how paranoid or conspiracy-minded you are, what the government is actually doing is worse than you imagine" W.Blum
Re: FRAM TG3614 and WIX 51348 cut open [Re: jrustles] #3463296
08/23/14 06:59 PM
08/23/14 06:59 PM
FEMA Region 4
jk_636 Offline
jk_636  Offline
FEMA Region 4
I can feel the exuding sarcasm from here crackmeup
Re: FRAM TG3614 and WIX 51348 cut open [Re: mrsilv04] #3463323
08/23/14 07:23 PM
08/23/14 07:23 PM
wisconsin
steveh Offline
steveh  Offline
wisconsin
TG= Tender Guard.
Re: FRAM TG3614 and WIX 51348 cut open [Re: HX520W] #3463385
08/23/14 08:27 PM
08/23/14 08:27 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
It looks like the seam split open on the Fram.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: FRAM TG3614 and WIX 51348 cut open [Re: HX520W] #3463396
08/23/14 08:38 PM
08/23/14 08:38 PM
FEMA Region 4
jk_636 Offline
jk_636  Offline
FEMA Region 4
Maybe the "junk" that the filter caught between the pleats were actually, in fact, disintegrated pieces of the Fram TG filter!
Re: FRAM TG3614 and WIX 51348 cut open [Re: HX520W] #3463407
08/23/14 08:57 PM
08/23/14 08:57 PM
Virginia
mattwithcats Offline
Virginia
You can use a Fram 3600 / Purolator 20195 instead of the 3614...
It's a third longer, same base and bypass pressure...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: FRAM TG3614 and WIX 51348 cut open [Re: HX520W] #3463418
08/23/14 09:03 PM
08/23/14 09:03 PM
TN
HX520W Offline OP
HX520W  Offline OP
TN
What's with all the hate? It seems like every thread with a FRAM in it is full of confirmation bias. frown
Re: FRAM TG3614 and WIX 51348 cut open [Re: jk_636] #3463423
08/23/14 09:08 PM
08/23/14 09:08 PM
TN
HX520W Offline OP
HX520W  Offline OP
TN
That's absolutely false.
Re: FRAM TG3614 and WIX 51348 cut open [Re: HX520W] #3463444
08/23/14 09:40 PM
08/23/14 09:40 PM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
Both filters look good, but the Wix "looks" better. The TG has superior filtration specs though. I would stick a paper clip or something down in that seam to see if it was really split. I doubt it.
2012 Honda Accord EX-L K24z3
54,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
40,xxx miles
Castrol OEM dealer fill / OEM filter
