Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
USS Theodore Roosevelt
by BMWTurboDzl - 04/03/20 03:42 PM
2020 Subaru Forester Base
by wagsrk08 - 04/03/20 03:41 PM
New Rislone Hy-per Fuel Product?
by Jackson_Slugger - 04/03/20 03:38 PM
Rislone New Gas Hy-per Cleaner Rebate
by Jackson_Slugger - 04/03/20 03:33 PM
2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil
by apollo18 - 04/03/20 03:15 PM
FRAM Extra Guard PH16 CUT OPEN
by 53' Stude - 04/03/20 03:11 PM
CARQUEST R 84502 CUT OPEN 4,600 MILES
by 53' Stude - 04/03/20 02:58 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
102 registered members (AlienBug, aquariuscsm, ArrestMeRedZ, Alaskanmont, asiancivicmaniac, 2015_PSD, 8 invisible), 2,101 guests, and 19 spiders.
Topics303,549
Posts5,237,276
Members71,086
Using AT-205 Re-Seal Topically #2166418 02/09/11 05:52 PM
F
Frbl Offline OP
F
A certain internet auto repair and maintenance "guru" has recently recommended using AT-205 Re-Seal on certain chassis parts to stop squeaks.
It is usually used directly in the oil sump to fix seal leaks, but the idea here seems to be be one of preserving or perhaps renewing things like bushings.
What little I have found on BITOG simply mentions that it is a plasticizer, seems not to contain petroleum distillates, and has mixed reviews from some BITOGers. Most objections seem to relate to its use inside the oil sump or transmission.
I am thinking of using it topically as preventative maintenance on bushings, brake lines, and cv boots. Does anyone have am opinion on whether this would be a waste of money, potentially beneficial, or possibly destructive?
I have been using 303 Protectant, but I wonder if AT-205 might not just preserve but actually restore these items.
Re: Using AT-205 Re-Seal Topically [Re: Frbl] #2166467 02/09/11 06:37 PM
W
willix Offline
W
Interesting thought, I am not familiar with thew product you speak of. The only thing I don't follow is the concern over bushings.
I like the Idea of using the treatment on only the leaking seal.
I would think the effectiveness may be limited however you would be able to treat the seal with full strength product instead of using it as an oil additive.
I could imagine the boot becoming soft & stickier when bellows make contact with eachother.
Many times seals fail due to wearing a groove in the rotating steel or iron surface.
Brake lines & boots may be a bad idea. If it soaks thru the brake hose plys it will compromise its ability to retain its burst specifiaction.
CV boots only need silicon spray to preserve & prevent the bellows from binding together.
Re: Using AT-205 Re-Seal Topically [Re: Frbl] #2169324 02/12/11 06:29 PM
dailydriver Offline
I have actually used this stuff for RUBBER suspension bushings ONLY (I would NOT put it on rubber brake lines, and would be hesitant to use it on steering rack/CV joint bellows).
I buy the liquid bottle and pour it into a pump spray bottle.
DO NOT put too much of this on or it WILL turn the bushing you are trying to swell/quiet to MUSH.
Just wet it slightly and let it soak in.
It DOES work for me, especially on the front lower control arm rear bushings which are a PAIN to replace. wink
2016 Ford Fiesta ST 17K miles
Ravenol REP 5W-30
Fram XG3600 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Using AT-205 Re-Seal Topically [Re: dailydriver] #2169835 02/13/11 10:35 AM
F
Frbl Offline OP
F
Thanks for the warning. I was tempted to do exactly as you describe regarding the non-bushing components. Just 303 Protectant for them!
Re: Using AT-205 Re-Seal Topically [Re: Frbl] #2169840 02/13/11 10:38 AM
V
Vikas Offline
V
The only place that I have found this is from Amazon merchant which tacks on shipping. Any cheaper source of it?
Yah, I like that internet "guru" along with RichPin, EricTheCarGuy and RealFixesRealFast. Anybody else is a hack or don't know how to keep camera on a tripod.
- Vikas
Re: Using AT-205 Re-Seal Topically [Re: Vikas] #2169855 02/13/11 11:08 AM
F
Frbl Offline OP
F
- Vikas
I found it locally at a locally owned auto store. Besides Amazon, I have not been able to find it online either.
Re: Using AT-205 Re-Seal Topically [Re: Frbl] #2171317 02/14/11 08:16 PM
dailydriver Offline
Every single Napa I've visited in my area has it right on the shelf (some even carry the small aerosol can version as well).
A lot of the independent stores also have it on the shelf.
Ravenol REP 5W-30
Fram XG3600 filter
Re: Using AT-205 Re-Seal Topically [Re: Frbl] #2171724 02/15/11 10:20 AM
V
Vikas Offline
V
Can somebody get me a NAPA part number that can be looked up?
Re: Using AT-205 Re-Seal Topically [Re: Vikas] #2172868 02/16/11 02:14 PM
W
willix Offline
W
Re: Using AT-205 Re-Seal Topically [Re: Frbl] #2173180 02/16/11 08:14 PM
V
Vikas Offline
V
Thanks for nothing :-(
You think I did NOT search on NAPA online for this particular product?
- Vikas
Re: Using AT-205 Re-Seal Topically [Re: Frbl] #3459424 08/19/14 10:38 AM
B
babbittd Offline
B
This is an old thread, I know, but I have never seen AT-205 in a NAPA store, or any other for that matter. Which may just mean that it not available OTC in this area.
However, I did find another internet retailer that sells it and I think the shipping charge is lower than amazon's.
http://www.summitracing.com/parts/atp-at205
