Another Civic Down
by ctechbob - 07/06/20 01:25 AM
Garden Hose for Gasoline Transfer?
by viscous - 07/05/20 11:55 PM
Changing coolant-water ratio of 50-50 premix?
by TrustyAutos - 07/05/20 11:27 PM
ring terminals - really?
by DirtyOilGuy - 07/05/20 11:27 PM
Which oil is better out of these
by Bazza32 - 07/05/20 11:08 PM
Automatic transmission shift feel
by Spetz - 07/05/20 10:51 PM
Opinions On This Laptop
by BlueOvalFitter - 07/05/20 08:02 PM
Anyone else see Hamlin hood flap fly out?
by 555 - 07/05/20 07:54 PM
Husqvarna AWD with a Honda engine
by yeehaw1960 - 07/05/20 07:02 PM
Recommended car shipper?
by HawkeyeScott - 07/05/20 06:10 PM
My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
carms, Ben2, Turboman92, TrustyAutos, TacoFergie
71854 Registered Users
62 registered members (alarmguy, 2010Civic, aquariuscsm, ARB1977, agarb, 94astro, 6 invisible), 1,270 guests, and 25 spiders.
Topics307,469
Posts5,311,779
Members71,854
2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) #3438505 07/28/14 01:45 PM
E
EdwardC Offline OP
E
First UOA report!
Forgot I got this analysis done a while ago:
6,037mi on the sample, OLM reported 0% (-137mi, actually). Oil was 5 months old so it had all the super cold polar vortex miles.
Air filter is a 2 years, 19.5k old FRAM.
Oil filter is OEM A01. I did not replace the filter, refilled it with QSUD 0W20.
Prior two oil changes used the same M1 0W20 AFE.
The car is mostly a short trip or stop and go in the city driving, except for longer road trips (I'd estimate once a month). In the super cold weather this year (under 20F), I typically let it warm up a tiny bit while I got settled in.
Overall, pretty uneventful UOA, I think, how about you all? Thanks for reading!
Re: 2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) [Re: EdwardC] #3438645 07/28/14 04:15 PM
R
route66mike Offline
R
New viscosity for that oil is KV100=8.5, yours is down a bit, might be fuel dilution doing that. Other wear metals are low, nice! Seems like you could have topped off with a M1 0w-40 to get viscosity up a bit and gone another 6,000 miles.
Re: 2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) [Re: EdwardC] #3438722 07/28/14 05:35 PM
E
EdwardC Offline OP
E
That's not a bad idea at all. Part of the reason I'm running the UOA is to see if I can extend the OCIs.
Assuming a 5qt sump, I could start with 4.5qt on the initial fill (about half way on the dipstick), then when the OLM hits 15%, I add .5-1 qt of) 0W30/0W40/5W30 to boost the TBN a bit and bring up the viscosity and reset the OLM. Then when the OLM hits 15% again, I'll be at about 10k and I can start over (with a new filter).
Widman calculator ( http://www.widman.biz/English/Calculators/Mixtures.html ) estimates that at 100C, 90% of the depleted 7.5 cSt mixed with 10% 0W40 at 13.5 cSt would yield a 7.93 cSt.
Re: 2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) [Re: EdwardC] #3438728 07/28/14 05:44 PM
deven Offline
You can easily run 10,000 mile oil change intervals with any good synthetic oil in your Element even without doing UOA's. Honda's are just not that hard on oil.
Proud user of ROYAL PURPLE products!
2020 Tesla Model S Performance.
2016 Toyota Camry XLE Hybrid. Toyota 0w20. OEM Filter. 10,000 mile OCIs.
KEEP IT SIMPLE STUPID. IT'S ONLY OIL
Re: 2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) [Re: EdwardC] #3438762 07/28/14 06:21 PM
O
Oregoonian Offline
O
Defiantly can increase the UOA's to between 8000 to 10,000.
M-1 0w20 AFE is an excellent year-round oil that I've been using for several years now. My last UOA was at 9200
If you increase your UOA to that area, I would suggest getting a Fram ULTRA filter, wich is much praised here by BITOG'ers, and can easily do 10K plus UOA's At just under $9 at WalMart, the ULTRA is "best value for the buck" category. If you decide on doing shorter UOA's, you should be able to use it through two oil changes (2 X 7500 = 15,000), because its guaranteed for 15K by Fram.
03' Ford Focus SE(2.3L Duratec PZEV)/ 140K +
Pnz. Ultra 0w20 / Fram 'Ultra'/ OCI: 8000 +/-
ATF: Mercon V w/Lubegard Red
Re: 2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) [Re: EdwardC] #3439002 07/28/14 09:30 PM
E
EdwardC Offline OP
E
I know that the Fram Ultras are known to be good filters, with significantly better filtration than OEM filters, but other than that, is there any reason not to keep using the OEM?
The owner's manual specifies changing the filter every other oil change, so I'm already using the filter to 12k or so.
Regardless, I'm going to push my intervals to about 10k, or 100% -> 15% on the OLM twice.
Re: 2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) [Re: EdwardC] #3440893 07/30/14 05:23 PM
O
Oregoonian Offline
O
The Fram Ultra can also be used for two OCI's (totaling up to 15K). In most cases the ULTRA has better efficiency than most, if not all OEM's (99+ percent 20 microns).
At under $9 at WalMart, its been said to be "the best bang for the buck" of any high-end, long OCI filter.
Re: 2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) [Re: EdwardC] #3440912 07/30/14 05:43 PM
9
901Memphis Offline
9
The paint job on the Ultra is more rugged than most, so it lasts longer to salt exposure, and the holding capacity is higher than OEM, so you could probably run them longer than the rated 15,000 miles or 2 FCI if you wanted to get the most out of the filter.
The K24 likely won't care what filter you use since they wear so well anyways, but the Ultra surely filters more out of the oil than the OEM filter.
2012 Chevy Cruze LT 1.4T - 80k - Trifecta Tuned - Amsoil SS 5w30 + Amsoil EA15K35
2009 Chevy Cobalt LS 122k - PP HM 5w30 + Fram Ultra
Re: 2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) [Re: EdwardC] #3459110 08/18/14 09:33 PM
G
gregk24 Offline
G
Thank you for this UOA, I am running this oil with a Fram Ultra on my K24 next OCI. That AL is a little higher than normal, but not bad considering the conditions.
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: 2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) [Re: deven] #3459647 08/19/14 04:39 PM
J
jayg Offline
J
Depends on the Honda.
2019 Toyota Prius E-AWD- TGMO 0w16
2017 Ram 1500 Ecodiesel- CP Triton ECT 5w40
1973 Datsun 240Z 10w30- VWC from '73
...and a bunch of old motorcycles
Re: 2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) [Re: jayg] #3459824 08/19/14 08:40 PM
H
HKPolice Offline
H
Ya, none of these newer K or R series engines are "easy on oil". This engine sheared the oil from ~8.5 cST to 7.5 after 6k miles in 5 months. If he had gone to 10k it'll probably be close to 6 cST which is near out of spec.
Re: 2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) [Re: HKPolice] #3459838 08/19/14 08:51 PM
G
gregk24 Offline
G
[quote=HKPolice]Ya, none of these newer K or R series engines are "easy on oil". This engine sheared the oil from ~8.5 cST to 7.5 after 6k miles in 5 months. If he had gone to 10k it'll probably be close to 6 cST which is near out of spec.
Yeah, and it would have probably returned the same wear numbers.
61,xxx miles
54,xxx miles
Re: 2007 Honda Element 6037mi, M1 0W20 AFE UOA (K24) [Re: HKPolice] #3460150 08/20/14 10:19 AM
G
gonefishing Offline
G
I think just about every UOA I have seen with M1 0W-20 has shown some shear. It seems to do this right off the bat then stabilize. I don't think it would ever get to 6 cSt unless there was a lot of fuel present.
7.6 cSt: http://www.bobistheoilguy.com/forums/ubb...i-2#Post3410105
7.2-7.5 cSt: http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3433883/1
7.4 cSt: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Main=163019&Number=2404218
7.6 cSt: http://www.driveaccord.net/forums/showthread.php?t=55916
2014 GMC Sierra 1500 SLT All-Terrain 5.3 4x4
