Gifted a 2007 Impala
by 14Accent - 11/12/19 11:02 PM
Premium vs. Budget Snow tires
by edyvw - 11/12/19 10:11 PM
Range Rover 5.0 oil & BG MOA?
by xmreeves - 11/12/19 09:34 PM
Stalling and difficult restart problem
by RDMgr - 11/12/19 09:26 PM
New Fave way to remove snow from vehicles
by JC1 - 11/12/19 08:19 PM
Shying Away From Havoline 5w30
by Mr_Luke - 11/12/19 08:00 PM
New Way To Wash A Car
by buster - 11/12/19 07:52 PM
Sealed vs open bearings. What's better?
by motor_oil_madman - 11/12/19 07:51 PM
Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
Mobil 1 FS 0w40 vs Castrol 0w40
by Ndx - 11/12/19 04:14 PM
Hombre909, DeLong, Scuder, Jasonrmcc, Capacc
69840 Registered Users
65 registered members (2015_PSD, ArrestMeRedZ, alchargo, another Todd, Aichiguy, 69Torino, 6 invisible), 1,224 guests, and 20 spiders.
Topics297,340
Posts5,113,483
Members69,840
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Home Brew CLP's #3437179 07/27/14 09:11 AM
ChrisD46 Offline OP
I have collected the following off of the web - not sure how all of them work but many sound interesting and in the spirit of this web site may be worth trying (YMMV) :
CLP’s :
7 parts M1 20W50 V- Twin Motorcycle Oil
2 parts Dextron IV
1 part MMO
4 parts M1 5W30 ~ 20W50
2 parts Dextron IV
2 parts STP Oil Treatment (Blue Bottle)
2 parts MMO
1 part Hoppes #9 Bore Cleaner OR
1 part Mineral Spirits
6 parts M1 20W 50 V - Twin Motorcycle Oil
2 parts Dextron IV
4 oz. M1 5W30 ~ 20W50
2oz. Dextron IV
1.9 oz. STP Oil Treatment (Blue Bottle)
0.5 oz. Hoppes #9 Bore Cleaner
7 parts M1 20W 50 V- Twin Motorcycle Oil
3 parts Dextron IV
2 parts M1 5W30 ~ 20W50
2 parts Dextron IV
3 parts STP Oil Treatment (Blue Bottle)
1 part MMO
1.5oz. M1 5W30 ~ 20W 50
1 oz. Dextron IV
1 oz. MMO
0.5 oz STP Blue Oil Treatment (Blue Bottle)
10 parts Lucas Air Tool Oil
Add Dextron IV until mixture becomes red in color
2 parts M1 20W 50 V- Twin Motorcycle Oil
2 parts Dextron IV
1 part MMO
1 part STP Blue Bottle Oil Treatment
1/8 oz. Hoppes #9 Bore Cleaner
4 parts M1 5W30 ~ 20W 50
2 parts Dextron IV
0.95 parts STP Blue Bottle Oil Treatment
0.45 parts Hoppes #9 Bore Cleaner
Final Lube:
2 parts M1 5W20 V- Twin Motorcycle Oil
1 part Dextron VI
1 part Lucas Air Tool Oil
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Home Brew CLP's [Re: ChrisD46] #3437529 07/27/14 03:35 PM
tom slick Offline
You'll have a tough time finding Dextron IV for your tests.
They all seem to be variations on a theme.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Home Brew CLP's [Re: ChrisD46] #3437570 07/27/14 04:18 PM
H
hatt Offline
H
Most of those look like they have nothing in common with CLP. Probably be better off going with a 50/50 mix of ATF/motor oil and kerosene than some of those.
2013 F150 5.0, Delo XLE CK-4 10W-30, Baldwin B7449
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Home Brew CLP's [Re: ChrisD46] #3437607 07/27/14 04:48 PM
Astro14 Offline
Since you can get a 16oz supply of CLP for less than $20, how much are you really saving with a home brew? All those ingredients have a cost as well...so the savings is a few dollars per year...for something that doesn't work as well on a collection of guns that is worth, what, many thousands of dollars?
Seems a false economy to me...
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Home Brew CLP's [Re: ChrisD46] #3438204 07/28/14 07:44 AM
ChrisD46 Offline OP
* My bad - Should be Dextron VI nor IV !
* Grant Cunningham's site has interesting information on CLP's that may change your mind .
* Lucas Red #2 Grease suitable for slides comes in a large 16oz. tub for $6.00 while the same #1 or #2 grease for guns comes in a small syringe for $7.00 + .
* A lot of 1911 semi - auto owners use M1 20W 50 or a M1 / Dextron VI mix with very good results !
* I own and use : Balistol , Slip 2000 EWL , Weapon Shield and MPro 7 to name a few ... I would not consider making anything on my own unless I already had the ingredients on the garage shelf . Glocks & Rugers are not too picky regarding what you CLP them with .
Re: Home Brew CLP's [Re: ChrisD46] #3438209 07/28/14 07:50 AM
H
Hokiefyd Offline
H
You won't find that either...
It's Dexron. No 't'.
http://en.wikipedia.org/wiki/DEXRON
Re: Home Brew CLP's [Re: ChrisD46] #3438230 07/28/14 08:16 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I don't quite get it. Why not just go for the viscosity you're aiming for first, rather then making a mix that yields an intermediate viscosity. If some other additization intrinsic to motor oil is desirable, just add it...
Re: Home Brew CLP's [Re: JHZR2] #3438260 07/28/14 08:59 AM
strat81 Offline
I use motor oil and ATF in a 50/50 ratio. I wasn't aiming for a particular viscosity, I used what was readily available, in my case Supertech 5w-30 Synth and ST Dex/Merc ATF. The ATF makes my AR a bit easier to clean versus straight motor oil, and this combo product lasts longer under use than Breakfree CLP on an AR BCG.
The nice thing about a motor oil/ATF combo is that pretty much anyone can try it for virtually no investment. Use the leftovers from a fluid change. Even an ounce of each will be plenty for a test. Repurposed contact lens solution bottles work well for that.
I'll also add that I use it for lubrication only. It is too "sticky" to use as a protectant. Surfaces that need rust protection get a wipe of Boeshield T9.
Molon Labe
Re: Home Brew CLP's [Re: ChrisD46] #3438341 07/28/14 10:07 AM
L
L_Sludger Offline
L
The AR boys like M1 synthetic (not sure of grade) in their bolt carrier groups.
Re: Home Brew CLP's [Re: ChrisD46] #3438410 07/28/14 11:07 AM
R
Robenstein Offline
R
In a pinch I have found liquid wrench chain lube to be a good ersatz gun lube. Like gun lubes it has extreme pressure additives, goes on thin but thickens to resist "sling off", had corrosion inhibitors for steel components, and is pretty darn cheap.
2011 Triumph Speedmaster
1986 Chevy Monte Carlo SS
1970 Chevy Nova
2006 Scion TC
Re: Home Brew CLP's [Re: ChrisD46] #3438553 07/28/14 01:21 PM
ChrisD46 Offline OP
* Dexron it is !
* I didn't create any of the recipes , I just reported what I found on various sites .
* My weapons get rubbed down with Corrosion X and then only areas that need grease or a lube get it .
Re: Home Brew CLP's [Re: Astro14] #3438730 07/28/14 04:46 PM
B
bubbatime Offline
B
BINGO!! Close thread.
2019 Honda CRV 1.5T factory bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: Home Brew CLP's [Re: ChrisD46] #3439459 07/29/14 11:04 AM
ChrisD46 Offline OP
Some exotic gun lubes are quite expensive in comparison (i.e. Gun Butter , Frog Lube) - besides what Grant Cunningham has to say on his web site about lubrication of firearms , there are countless others in the 1911 and AR semi - auto community who shoot more in a week then I do in a whole year who swear by "Ed's Red" CLP and other offshoot recipes I included here for grins . Perhaps due to the platforms they shoot (AR and 1911) and running these weapons wet - they find M1 20W 50 V-Twin synthetic oil , Dexron VI ATF, etc. to be quality lubricants which they consider cost effective . That said , I'm fine with people who decide that Break Free CLP is perfect for their usage based on how much they shoot .
Re: Home Brew CLP's [Re: ChrisD46] #3440083 07/29/14 08:41 PM
H
hatt Offline
H
"Ed's Red" is totally different than anything you posted here. It actually looks like it would be of use but I've never tried it.
Equal parts ATF/kerosene/mineral spirits/acetone.
Bottom line is that if you're shooting enough that lube costs are getting high, money isn't an issue in the first place. A gallon of CLP is $80. Or about 250-300 rounds of cheap .223.
Re: Home Brew CLP's [Re: ChrisD46] #3440107 07/29/14 09:11 PM
AMC Offline
Besides all of the above arguments against using home made CLPs, One thing to remember is that all the homebrews are going to stink! You do not want to spill any of those homebrews or use them inside if you or anyone else in your house has a sensitive nose.
I actually used to use (years ago) ed's red as my general gun cleaner. The bad smell and head aches were the reasons I stopped using it.
That is one of the main reasons I like Breakfree CLP and CorrosionX so much, they have almost no odor. If you really like ZERO odor, super lube is the best. I also like and recommend ballistol but its strong black licorice smell turn a lot of people off.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - QSUD 5w-20
14 Yamaha Super Tenere - Delo XLE 15w-40
Page 1 of 3 1 2 3
