Battery warranty Issue at Pep Boys
by InhalingBullets - 11/19/19 08:35 AM
How Often To Use CRC IVC ?
by ChrisD46 - 11/19/19 03:28 AM
SEARS: 4 Stroke/Lawnmower Maintenance Deals
by GumbyJarvis - 11/19/19 02:17 AM
Pepboys Coupon
by Xeno - 11/19/19 02:12 AM
Pennzoil “Designed for Your Drive”
by LubeFiner - 11/19/19 02:09 AM
Ebay $15 of $75 purchase
by GMguy84 - 11/19/19 12:06 AM
How thorough are coolant flushes at auto shops?
by Whammo - 11/18/19 10:58 PM
Fixed Orifice PCV design and issues.
by Talent_Keyhole - 11/18/19 10:44 PM
Redline Si-1 turning the light out
by lukejo - 11/18/19 10:16 PM
Quickjack BL-7000EXT
by The Critic - 11/18/19 08:27 PM
'17 Accent
by Al - 11/18/19 07:40 PM
considering a newer car.
by JustinH - 11/18/19 06:56 PM
2007 Accord - P0420 Code
by maverickfhs - 11/18/19 06:52 PM
2009 Ford Focus UOA Mag 1 5W30 4265 miles
by tomcruise - 11/18/19 06:09 PM
What’s in HM oil ?
by kstanf150 - 11/18/19 06:03 PM
Heater Core replacement 1997 Explorer
by racer44 - 11/18/19 06:01 PM
No shocker, but a rip-off story...
by KGMtech - 11/18/19 05:55 PM
AGM Question
by Bear - 11/18/19 05:36 PM
1970 engine noise
by 007 - 11/18/19 04:59 PM
Jalopnik Financial Suggestion
by madRiver - 11/18/19 04:46 PM
Joe_Cena, MickWK, DaveOilStack, spiffy63, WhiteMega1227
69911 Registered Users
98 registered members (5azzmonkey, 1978elcamino, A310, 53' Stude, 64bawagon, 379KITTY, 7 invisible), 1,837 guests, and 22 spiders.
Topics297,620
Posts5,119,501
Members69,911
Most Online3,589
Nov 2nd, 2019
Page 5 of 10 1 4 5 6 10
Re: New To BMW and Synthetics [Re: sprintman] #3422039 07/11/14 06:25 PM
B
Bluestream Offline
B
Originally Posted By: sprintman
Originally Posted By: Garak
You could grab an approved lube or reasonable facsimile thereof. That would include the real BMW approved A3/B4 type lubes such as GC (and its brothers) or M1 0w-40.
That's right. If something like M1 0w-40 existed when that BMW chart was created, that whole gamut of different oil grades and temperatures could have been replaced by this one oil.
Which is EXACTLY what they did when they started spec'ing LL-98 , LL-01....etc. BMW Synthetic 5w-30 (and its equivalents) replaced that chart.
No BMW 5W30 here and not available in most countries. One to ponder....
Dont worry, it will get there eventually...
2000 VW Beetle 1.8T M5
2006 Pathfinder 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
Re: New To BMW and Synthetics [Re: camrydriver111] #3422291 07/11/14 11:16 PM
sprintman Offline
No CAFE here, so not it won't
Re: New To BMW and Synthetics [Re: sprintman] #3422306 07/12/14 12:22 AM
G
Garak Offline
G
We have no CAFE here, but I bet it made it here.
Plain, simple Garak.
Re: New To BMW and Synthetics [Re: camrydriver111] #3422332 07/12/14 02:20 AM
R
riggaz Offline
R
Those engines need 0w30, 0w40 or 5w40 LL01 6.5 litres
all those oils are fit and forget and with that mileage will last a long time
nice motor!
Re: New To BMW and Synthetics [Re: Bluestream] #3422337 07/12/14 02:43 AM
R
riggaz Offline
R
For one thing, MPG. My gas consumption goes up 40% in the winter and that is mostly due to thick fluids caused by the cols weather.
You might find it's due to the winter grade fuel as well. It's no way near as "pure" as summer grade fuel. We have a drop in mpg in England on winter fuel so it's probably much worse at your temps.
Re: New To BMW and Synthetics [Re: riggaz] #3422345 07/12/14 03:53 AM
chrisri Offline
You might find it's due to the winter grade fuel as well. It's no way near as "pure" as summer grade fuel. We have a drop in mpg in England on winter fuel so it's probably much worse at your temps. [/quote]
Are you sure there is a difference between winter and summer petrol?
02 Nissan Terrano 2.7.TDi Total 5w40
06 FIAT Stilo MW 1.9 Multijet SHU 5w40
07 Opel Vectra SW 1.9 CDTI 150 Motul 5w40
Re: New To BMW and Synthetics [Re: sprintman] #3422391 07/12/14 05:39 AM
Q
Quattro Pete Offline
Q
The BMW 5w30 is an ACEA A3/B4 high HTHS oil, so not exactly CAFE friendly either.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: New To BMW and Synthetics [Re: camrydriver111] #3422469 07/12/14 07:08 AM
R
ryan2022 Offline
R
Do they have kendall euro 5w40 where you are? I used that in our SLK when we had it, annual changes, and worked beautifully.
Theres also Pennzoil 5w40 which Napa usually has.
2011 Subaru Impreza Hatchback 5w30 Mobil 1
2015 Subaru Outback 2.5 Limited 0w20 Mobil 1 AFE
1995 Nishiki Navajo mountain bike....some kind of chain oil.
Re: New To BMW and Synthetics [Re: riggaz] #3422621 07/12/14 11:45 AM
B
Bluestream Offline
B
Its not the fuel, although that is a common misconception. The fuel is distilled to be more :volatile" to aid starting in cold temps.
2006 Pathfinder 4X4
1991 BMW 735iL
Re: New To BMW and Synthetics [Re: Bluestream] #3422714 07/12/14 01:44 PM
B
BMWTurboDzl Offline
B
Well higher volatility usually mean lighter and less BTU
435i
Re: New To BMW and Synthetics [Re: camrydriver111] #3422731 07/12/14 02:11 PM
Shannow Offline
BMWTurboDzl, yep, that's pretty well generally true...historically winter was when they added oxygenates to keep the HC and smog down too...there goes some mileage.
Worst change I've (personally) seen was 10%, switched from SAE30 over summer to 25W70 through winter in my J Car wagon...(albeit only got to -7C)...notably harder cranking, 10% poorer mileage on 10 mile commute, and no perceptible difference on the highway.
Re: New To BMW and Synthetics [Re: Shannow] #3422831 07/12/14 04:06 PM
B
Bluestream Offline
B
Try in -34C and report back
2006 Pathfinder 4X4
1991 BMW 735iL
Re: New To BMW and Synthetics [Re: riggaz] #3422869 07/12/14 04:34 PM
B
bigjl Offline
B
I have never experienced a drop in fuel economy in the winter.
I personally found fuel economy better in winter than summer due to not using aircon.
16 S350d LWB 25k Mobil Super 3000 XE 5w30
17 Smart ForFour Auto 6.5k Mobil 1 0w40 FS
Re: New To BMW and Synthetics [Re: Bluestream] #3423040 07/12/14 07:57 PM
G
Garak Offline
G
I have. 40% is a stretch unless there's some substantial idling and/or extremely difficult issues with rolling resistance thanks to unplowed streets. As I've already posted here, with numbers, I didn't see huge differences between summer or winter mileage. A statistically significant difference is possible, but, like I said, 40% indicates a lot of idling or terrible road conditions.
Re: New To BMW and Synthetics [Re: bigjl] #3423242 07/13/14 01:59 AM
chrisri Offline
[/quote]
Same here but it rarely drops below 5C in winter.Summers had far greater impact on my fuel economy due to a frequent use of aircon.
