Back in my day (70s), changing the coolant was easy. Just open the drain petcock, remove the fill cap, and drain. Then refill with water (and a flush if desired), run the engine until hot with the heater on, and drain again, One more flush with water, then refill with the coolant mixture.
So now I'm looking to replace the coolant on my 2008 Altima 2.5 SL and the instructions I am seeing online include things like using a vacuum pump and bleeding the system. Is this really necessary? Could I do harm by just doing the old fashioned drain and flush routine?
Tom NJ
Tom NJ
