Air Filters for Chonda 457cc engine
by 92saturnsl2 - 03/31/20 07:59 PM
Share your Hot Toddy recipe
by LoneRanger - 03/31/20 07:24 PM
Aftermarket CV axle boot replacement
by CDX825 - 03/31/20 06:34 PM
A few discounts at Walmart for buying 2 jugs
by jayjr1105 - 03/31/20 06:20 PM
Bumblebee Ahi tuna poke
by atikovi - 03/31/20 06:05 PM
2007 RDX Differential and Transfer Case?
by maverickfhs - 03/31/20 06:02 PM
Tacky additive in bar and chain oil
by TreyT42 - 03/31/20 05:02 PM
How Come Diesel is $2.69 when gas is $1.47 ?
by LoneRanger - 03/31/20 04:42 PM
Bosch Premium 3422 Cut Open
by getawheel - 03/31/20 03:52 PM
AC Went out in my Forester Again
by Miller88 - 03/31/20 03:48 PM
I'm out on the Front Porch
by MolaKule - 03/31/20 03:11 PM
Raybestos rotors - Element3 vs Specialty Truck
by RageOfFury - 03/31/20 02:39 PM
Briggs Stratton Quantum engine surging
by alex_at - 03/31/20 12:53 PM
Are harbor freight generators any good?
by NavyVet88 - 03/31/20 12:37 PM
Anyone on RD Forum .org? I've been banned
by FADEC - 03/31/20 11:48 AM
A picture of me in my youth! :-)
by SLO_Town - 03/31/20 11:18 AM
5w50 Motorcraft in 6.2L Raptor
by KlenFrappe379 - 03/31/20 11:16 AM
Fast 22 LR
by stockrex - 03/31/20 10:33 AM
Filter size info required please
by Richierich56 - 03/31/20 09:50 AM
Rickborn, TreyT42, Abi, Transpections, burgM
71068 Registered Users
119 registered members (92saturnsl2, Alfred_B, 762fermeandyou, Astro_Guy, antonmnster, 2K2AcuraTL, 12 invisible), 2,092 guests, and 20 spiders.
Topics303,522
Posts5,235,716
Members71,068
What grease for sway bar bushings? #3398408 06/15/14 07:37 PM
G
garlicbreadman Offline OP
G
The other day i stupidly decided to apply some 3m Silicone paste to my rear sway bar bushings(the bushings that hold the bar to the chassis). Totally disregarded that the bar is painted black from the factory so the 3m silicone lube was useless. A few days later i am getting annoying squeaks going over dips and bumps. Its very annoying. Prior to this, no noise at all.
I think what happened is that the lube glazed up between the bushing and sway bar and is causing the squeak. I sanded down the glaze from the bushing and sway bar. Im 1000% sure it is these bushings causing the noise. The bushings are rubber and the sway bar is painted BLACK from the factory. Anyone know of any rear sway bar bushing lube that mixes well with rubber bushings and the black paint of the sway bar? The bushing doesnt make direct contact with the metal off the sway bar.
Re: What grease for sway bar bushings? [Re: garlicbreadman] #3398429 06/15/14 07:54 PM
Doog Offline
The best lube is no lube.
Re: What grease for sway bar bushings? [Re: garlicbreadman] #3398434 06/15/14 08:01 PM
Pablo Offline
How did you apply the lube?
Did you take the bushings completely off?
Silicone grease or boat trailer bearing grease usually works fine.
DIRECT JOBBER - PABLO - for all your Amsoil needs
http://oilslubesandfilters.shopamsoil.com/
Re: What grease for sway bar bushings? [Re: garlicbreadman] #3398452 06/15/14 08:21 PM
E
EdwardC Offline
E
I swapped out those bushings and used silicone grease with no noise yet (this was just last fall though). I've read that petroleum based grease can cause the rubber boots on caliper slide pins to expand, so I figured it might be similar for the sway bar bushings.
Re: What grease for sway bar bushings? [Re: garlicbreadman] #3398458 06/15/14 08:34 PM
R
raytseng Offline
R
this depends, what kind of bushing you have.
If you have poly bushings, then you get poly bushing grease (e.g. prothane or energy):
http://www.prothanesuspensionparts.com/p...uoK_Z12Cb7w_wcB
Apply LIBERALLY, like 1 tube per bushing.. It actually goes on sticky like caulk but it is silicone grease.
If you have rubber bushings then no grease, but I would use the poly bushing grease as the good best alternative if you wanted to use something.
You sanded your bushings? If I were you, I'd get new bushings while you're ordering the grease if they are cheaply available and replaceable for your vehicle.
Re: What grease for sway bar bushings? [Re: garlicbreadman] #3398460 06/15/14 08:37 PM
cpayne5 Offline
How about a little teflon tape? A couple wraps around the swaybar keeps the poly bushings on my TSX quiet.
Re: What grease for sway bar bushings? [Re: garlicbreadman] #3398467 06/15/14 08:56 PM
spackard Offline
No grease is best, but PFPE-based grease doesn't have the stiction that silicon-based grease has. Expensive, but will be quiet.
Krytox 204.
Re: What grease for sway bar bushings? [Re: garlicbreadman] #3398477 06/15/14 09:07 PM
M
Merkava_4 Offline
M
Permatex brake caliper grease. It is a synthetic grease that looks like a green jell. You don't have to buy the big jar, you can get it in the little envelopes at Autozone in the Permatex section. Try some of that, it's good stuff.
Re: What grease for sway bar bushings? [Re: Pablo] #3398486 06/15/14 09:16 PM
G
G
Applied a thin coat. The sway bar bracket would force all the extra lube out, so i didn't liberally add it.
Re: What grease for sway bar bushings? [Re: cpayne5] #3398487 06/15/14 09:16 PM
G
G
wouldnt the teflon tape shred away in a matter of days?
I agree that no grease is best...but too late now. I will probably end up buying two new oem bushingsf or 5 each.
Re: What grease for sway bar bushings? [Re: garlicbreadman] #3398525 06/15/14 09:56 PM
B
barkingspider Offline
B
When I replaced the bushings on my escalade and my corvette, I wrapped the portion of the sway bar that would be covered by the bushing with Teflon tape, then I used syn valvoline grease on top of that. Then wipe off the excess. No squeaks at all.
04 Avalanche Z71 4x4
Re: What grease for sway bar bushings? [Re: barkingspider] #3398590 06/15/14 11:48 PM
G
G
Sounds promising, i'll give that a shot. How long has it been now?
Re: What grease for sway bar bushings? [Re: garlicbreadman] #3398699 06/16/14 07:40 AM
cpayne5 Offline
No, it will last quite a while, and costs next to nothing.
Re: What grease for sway bar bushings? [Re: cpayne5] #3399120 06/16/14 04:45 PM
G
G
I will give this a shot tonight and report back. Did you apply any lube?
Re: What grease for sway bar bushings? [Re: garlicbreadman] #3399178 06/16/14 05:53 PM
P
PhillipM Offline
P
None if they're rubber - the rubber is supposed to grip the bar and twist with it, so no noise, if you grease it, your noise is the bar moving in the rubber...put new bushes in, make sure it's clean, repaint the area you sanded off because spring steel is very susceptable to surface corrosion cracking, and don't grease them this time.
