Originally Posted By: dailydriver
CATERHAM;
Do you still hold to the claim that the SN, XOM made TGMO cannot possibly have the Sustina beating, 236 VI which others claim, and one oil analysis company has tested it at??
The 236 VI is just one VOA from a lab that's been wrong before and Toyota doesn't even claim it's that high.
If we had a second VOA from another lab confirming the VI that would get my attention. As it stands the evidence points in the direction of Sustina having a higher VI than SN TGMO.
Here are some observations:
-The base oil Sustina uses has a VI of 140. Even if XOM is using their best GP III+ Visom 4 base oil, it's VI is 136. Not a big difference but a difference nonetheless. That means it up to the polymer VII to make up the difference and them some. Certainly not impossible but unlikely.
-Sustina has a considerably lower KV40 spec' of 32.69cSt and the WearCheck VOA came in at 36.15cSt. Assuming both oils have the same nominal HTHSV of 2.6cP (that's what Sustina claims) then Sustina has a lower viscosity change between those two temperature points.
-And not directly connected to VI but Sustina has a very low MRV (9630cP) and CCS (3550cP) stat's. We don't know what it is for the latest SN TGMO but the original had a MRV of 18,000cP.
But this really is an unfair comparison since Sustina 0W-20, Nippon Oil's flag ship product, is considerably more expensive than TGMO. If the comparison is based on value, TGMO 0W-20 is the obvious winner.
CATERHAM;
