Oil on the plug where? The insulator or the tip?
And the distributor? If that o-ring is leaking, the oil will leak out of the engine into the distributor and eventually to the outside of the cap. Are you suggesting that oil is leaking from the distributor into the spark plug well and/or onto the tip?
Originally Posted By: Robb.
Hi 20,000 kilometers, not miles !
valve cover and spark plug gaskets replaced a few years ago.
Its only 1 plug with oil on it.. could it be the o ring seal on the distributor ?
or o rings on head see link
