Keeping downspouts clean
by Klutch9. 07/16/19 01:00 PM
Cellphone plans
by aquariuscsm. 07/16/19 12:59 PM
Concealed Carry and Training
by Al. 07/16/19 12:47 PM
Ugliest/Best Chrysler LeBaron
by GumbyJarvis. 07/16/19 12:34 PM
Its TIme to Stock up on Pennzoil Ultra
by ad244. 07/16/19 12:32 PM
2003 Jetta VR6 2.8L, 6 speed tarns
by LazyDog. 07/16/19 12:26 PM
Interesting read
by double vanos. 07/16/19 10:34 AM
Apollo 11
by Snagglefoot. 07/16/19 09:55 AM
Brake Pad Unboxing and Review
by krismoriah72. 07/16/19 09:40 AM
Limited Slip Additive
by Snagglefoot. 07/16/19 09:39 AM
Future of Chevy Bolt
by Snagglefoot. 07/16/19 09:04 AM
ST6607 on Honda CR-V 2.4L
by MontePrix28. 07/16/19 08:50 AM
2006 4runner Oil Leak After Synthetic
by Lucas_Jones. 07/16/19 08:46 AM
Quiet Small Engine
by Bailes1992. 07/16/19 08:26 AM
2005 C55 AMG oil recommendation
by TinyVoices. 07/16/19 08:26 AM
Uniroyal Tiger Paw Ice and Snow 3 - Reviews?
by Miller88. 07/16/19 08:09 AM
Wix XP oil filter deal
by Randy_R. 07/16/19 06:54 AM
Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai, Weatherdriver77
68670 Registered Users
109 registered members (324Matt, ad244, Al, 2010Civic, alchargo, Alfred_B, 13 invisible), 2,322 guests, and 25 spiders.
Topics291,942
Posts5,013,795
Members68,670
Most Online2,967
Mar 10th, 2019
Brush Hog Gear box lube #2586032
04/01/12 01:51 PM
04/01/12 01:51 PM
Carthage, TX
lilred67 Offline OP
lilred67  Offline OP
Carthage, TX
i replace the input shaft seal on my brush hog and i'm going to re-fill with gear oil. Owners manual calls for EP 90 gear oil. Would EP 85-90 or 85-140 be a suitable replacement gear lube? Or should i stick with the straight 90?
1967 C-10 Chevy truck, 350 V-8
2002 ford F-250 4x4 superduty, 7.3l powerstroke w/183,000 miles
2018 Toyota Tacoma 4x4, 3.5l V-6 w/28,000 miles
Re: Brush Hog Gear box lube [Re: lilred67] #2586049
04/01/12 02:11 PM
04/01/12 02:11 PM
Northern, NY
Rob_Roy Offline
Rob_Roy  Offline
Northern, NY
Assuming the gearbox doesn't run excessively hot, 80w90 or 85w90 should be fine. Keep an eye on the condition of the oil...it seems like those gearboxes love to collect moisture.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: Brush Hog Gear box lube [Re: lilred67] #2586211
04/01/12 04:42 PM
04/01/12 04:42 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
For Texas I would use
http://www.amsoil.com/storefront/svt.aspx
or an equivalent Mobil or a Redline gear oil.
"Science is a body of knowledge, a 'recipe', as it were, for reality. The totality of science is a collection of hard-earned nuggets, using math as a language of expression." Chip Cohen
Re: Brush Hog Gear box lube [Re: lilred67] #2586218
04/01/12 04:47 PM
04/01/12 04:47 PM
Michigan born but my heart bel...
JR Offline
JR  Offline
i run conventional 80w-90, 85/90w-140 in my box. that because i change it often because these thing seem to collect moisture.
97 F250HD 7.3 320K 01 Astro 220K
93 metroXFi 94.5K
01 Impala 300K
04 RTV900R 1150hrs
Re: Brush Hog Gear box lube [Re: lilred67] #2586501
04/01/12 09:20 PM
04/01/12 09:20 PM
Carthage, TX
lilred67 Offline OP
lilred67  Offline OP
Carthage, TX
thanks for your reply's. i filled it with Valvoline semi-syn 85/140 i had on hand.
Re: Brush Hog Gear box lube [Re: lilred67] #2590921
04/05/12 03:34 PM
04/05/12 03:34 PM
NW Ohio
Jim Allen Offline
Jim Allen  Offline
NW Ohio
I used LE-607 in mine, from Lubrication Engineers in Texas. No longer produced but it was a straight 90 grade designed for industrial gearboxes.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
Re: Brush Hog Gear box lube [Re: Jim Allen] #2594446
04/09/12 12:31 PM
04/09/12 12:31 PM
MA
fpracha Offline
fpracha  Offline
MA
The Duolec LE 1605 replaces the LE 607.
Re: Brush Hog Gear box lube [Re: fpracha] #2597765
04/12/12 02:54 PM
04/12/12 02:54 PM
Indiana
Dieselbob Offline
Dieselbob  Offline
Indiana
Is the moisture coming from the machine being stored outside, or is it just drawing condensation?
Re: Brush Hog Gear box lube [Re: lilred67] #3393863
06/10/14 10:51 AM
06/10/14 10:51 AM
pa
dixon700 Offline
dixon700  Offline
pa
What about synthetic 75w-90?
04.5ram CTD lots of parts delvac15w-40 just delvac next time Donaldson elf7349 02 elantra gt castrol edge10w-30 oem filter
Re: Brush Hog Gear box lube [Re: lilred67] #3394366
06/10/14 09:14 PM
06/10/14 09:14 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
Corn head grease mixed with regular grease. You can run with a seal out with that.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Brush Hog Gear box lube [Re: lilred67] #3394848
06/11/14 02:10 PM
06/11/14 02:10 PM
MN
ironman_gq Offline
ironman_gq  Offline
MN
cornhead grease is pretty fluid when it warms up but does stiffen up when it cools off, it would keep it from drooling as much from a leaky seal when the machine is sitting. Not sure how well it would lubricate the unit in this application.
Re: Brush Hog Gear box lube [Re: lilred67] #3398138
06/15/14 11:52 AM
06/15/14 11:52 AM
Louisiana
SuzukiGoat Offline
SuzukiGoat  Offline
Louisiana
We run mystik 80w90.
I had a 40 year old bush hog that leaked a half quart an hour, grease fitting and four tubes of grease later...the box outlast four belly repairs.
2003 Nissan Xterra 4x4 M1 HM 10w40
2001 Toyota 4runner 4x4 M1 0w40
2016 Yamaha YXZ1000R VR1 20w50
Re: Brush Hog Gear box lube [Re: lilred67] #3398493
06/15/14 09:19 PM
06/15/14 09:19 PM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
I've been running 85w140. Those boxes take a beating, the thicker the film strength, the better!
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Brush Hog Gear box lube [Re: lilred67] #3413205
07/03/14 07:50 AM
07/03/14 07:50 AM
In the field
Alltherage Offline
Alltherage  Offline
In the field
our bush hog finish mower has a bad bottom seal. I switched from gear oil to JD cornhead grease and it improved in terms of leakage. It's changes from a soft solid when cold to a gear oil type substance when warm. I researched it quite a bit before using it and see no issues at all. It still leaks though, so now I want to mix the regular grease in with it or go to 100% grease. Seems that many others have had success with that when confronted with a really bad seal.
