OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
The Jeep Made it to 150k Miles - Storytime
by Nick1994 - 02/23/20 12:54 AM
Supertech vs Dexcool
by WA1DH - 02/22/20 11:44 PM
Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Chaucha, UofA, Jeffrey78, Markovchain, o_s
70787 Registered Users
92 registered members (Aichiguy, 74Widebody, 4WD, ArrestMeRedZ, Aero540T, 2002 Maxima SE, 11 invisible), 2,307 guests, and 18 spiders.
Topics301,824
Posts5,203,446
Members70,787
case 580sk tractor/hydraulic fluid #3392962 06/09/14 10:28 AM
dixon700 Offline OP
Hello, I have recently bought a '94 case 580sk backhoe. I believe most of its life it's just had universal tractor fluid in it. The factory spec I believe is case hytran in everything except the engine. I'd have to go into a local case dealer, but seen $95 for 5 gal of hytran on the net. I been topping off with traveller's premium universal fluid. Soon I'd like to change the fluid out and get the best fluid in there as possible without giving up both my arms lol. I believe the hyd. System and transaxle hold something like 30 gal or so. I've also been told by a couple farmers that the John Deere hyguard is better. JD hyguard meets case's hytran spec, but not the other way around and people have had problems running hytran in jd tractors, but no problems running hyguard in case tractors. I'd just like to do what's best for my backhoe and I don't believe it's running cheap traveller's premium universal fluid. Any help with some proof would be nice. I'm thinking just running hytran so I know it's right and maybe it'll perform better.
04.5ram CTD lots of parts delvac15w-40 just delvac next time Donaldson elf7349 02 elantra gt castrol edge10w-30 oem filter
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3392982 06/09/14 10:54 AM
J
JayhawkRoy Online Content
Online Content
J
My local Case dealer sells Hytran Ultra for 5 gal/$76.60.
As far as I can tell, running JD Hy Gard would be OK, too. Greenpartstore sells 2.5 gal for $24.30, plus shipping. John Deere also lists the specific Case specs it meets, so you can do a quick comparison/verification. Your dealer may also be able to get 55 gal drum for you. I assume shipping would be prohibitive and local procurement your best option for either fluid.
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3392992 06/09/14 11:22 AM
J
JD4440 Offline
J
Hit up your local shell/pennsoil dealer
They have a fluid that meets the spec but the name escapes me at the moment.
o6 duramax = Mobil Delvac
o6 Vortec 8.1 = Shell 10w-30
o4 Yukon = PU 5w-30
99 Sonoma= Mobil 5w30HM
2008 Hustler Z = Amsoil ACD
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3392993 06/09/14 11:23 AM
I
IndyIan Offline
I
Running in winter much? I don't know if you can get it, but Petro Canada Duratran Synthetic seems to be hard to beat. For my next change I'm going to try some but I only need 2 buckets.
http://lubricants.petro-canada.ca/resour...amp;language=en
Shell Spirax S4 TXM is cheap locally for me. It probably meets your specs as well.
http://www.epc.shell.com/Docs/GPCDOC_Local_TDS_Canada_Shell_Spirax_S4_TXM_(en-CA)_TDS_v1.pdf
07 Focus ZXW, 5spd manual, 245km M1 5W30
18 Outback 2.5 CVT 35km 0W20
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3393504 06/09/14 08:43 PM
J
JD4440 Offline
J
^^ Spirax, maybe that's what I was thinking of
o4 Yukon = PU 5w-30
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3393844 06/10/14 09:27 AM
dixon700 Offline OP
Another oil that was mentioned to me was royal purple syntractor, but man that's a little rich for my blood. The hydraulics hold 29 gal then the transaxle is 5.5gal I think so a good synthetic might be a good idea for the transaxle they're really pricey to repair. I may just get the case hytran or the new Holland stuff that's the same thing seeing as how the nh dealer is closer. I just like to run good products that are proven in my stuff.
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3393858 06/10/14 09:44 AM
I
IndyIan Offline
I
Do they spec the same fluid for both the hydraulics and the drivetrain?
Tractor fluid in a tractor has to do both, but with seperate sumps I would assume each fluid could be made differently for the job it does?
If the service guys seem reasonable at the dealership, they should know what works as well.
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3393897 06/10/14 10:22 AM
dixon700 Offline OP
Hytran the whole way around I believe. I bought my tractor from a kubota dealer. Their tech said universal hydraulic fluid and 5 hat was all. I'm guessing kubota udt.
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3395641 06/12/14 11:35 AM
dixon700 Offline OP
Well they gave me 5 gal of eni: super tractor plus fluid. I don't think I'd trust that in my transaxle, but should be fine in the hydraulic sump that takes 29gal... I've always like mobil oils, would the mobil 424 oil be better than hytran? I can't find a sample on hytran. I'm not going to run just some cheap universal in the transaxle. The royal purple stuff is a little expensive to buy 12+ gals of so maybe mobil 424 or the shell or chevron equivalent since all 3 should be spectacular oils that are probably better than hytran and cheaper.
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3398192 06/15/14 12:43 PM
A
andyd Offline
A
I'm late to the dance. I would like to buy a gallon of Hy tran for my '77 IH Cadet 80 hydrostatic drive lawn mower. It is used for touch controls in big equipment too. Seeing as how the original lasted 37 yrs I dont want a 5 gallon bucket of it.
Thick oil is better grin2
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3398193 06/15/14 12:44 PM
A
andyd Offline
A
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3398330 06/15/14 05:08 PM
J
Online Content
J
The Case dealer nearest me sells gallons at about 21 per gallon. 2.5 gal is also available. Check with your local dealer.
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3402707 06/21/14 01:07 AM
dixon700 Offline OP
Closet case dealer that's 38 mi or so away has case hytran ultra for $76 for a 5 gal pail. Emailed a local oil supplier about hytran or an equivalent and still haven't received anything back. The $76/pail is as good of a price as I've found online of cheaper products after shipping. Like 15 gal of lube king case fluid was $300 with shipping. I'd like to hear back from the local oil/fuel vendor, and I'm also going to check on new Holland master trans which I believe is the same fluid. The nh dealer is closer and may be cheaper. I'd like the cheapest route possible, but I definitely don't want to slouch on oil quality. I just want to find a good quality oil to replace in the transaxle and get that junk fram filter off and put the Baldwin filter on that I have.
Re: case 580sk tractor/hydraulic fluid [Re: dixon700] #3510571 10/14/14 01:43 AM
dixon700 Offline OP
Found the transaxle actually holds 12gal. I bought universal tractor fluid from my local oil supplier. Its made by ConocoPhillips. Meets a lot of specs including hytran and jd hyguard. So 8 figured it should be a plenty good fluid for the transaxle.
