Vintage Sinclair promo
by HiPowerShooter - 02/18/20 11:29 PM
why did my Ford iolm go to 9% after 3k miles?
by dogememe - 02/18/20 11:15 PM
HUBB reusable stainless steel filter?
by Vern_in_IL - 02/18/20 08:41 PM
Ultrasonic carb cleaning problems
by atikovi - 02/18/20 08:05 PM
Cheeseburger pie
by P10crew - 02/18/20 07:25 PM
The midwinter detail.
by dan_erickson - 02/18/20 05:27 PM
Tired of Using Cassette Player with iPhone
by Gebo - 02/18/20 05:04 PM
STP oil filter
by Stinky123 - 02/18/20 04:41 PM
How is this possible
by V10 - 02/18/20 04:07 PM
Monroe made in Turkey
by atikovi - 02/18/20 03:31 PM
NSFBitog
by Ursatdx - 02/18/20 03:25 PM
Wider rear tires?
by drop - 02/18/20 03:07 PM
ROCKAUTO Coupon Codes
by jrvn - 02/18/20 02:24 PM
Gold (brass?) flecks in drained Honda ATF
by TNM6i - 02/18/20 12:10 PM
What happened to licensed ATF clones?
by TimN3QE - 02/18/20 12:08 PM
E85 in non-flex fuel Ford Expy ~2013
by DriveHard - 02/18/20 11:46 AM
Jacking up a car by itself
by Alfred_B - 02/18/20 11:44 AM
Valvoline MST in 2015 Macan S
by musclecarscott - 02/18/20 11:43 AM
GardenStateAudi, Strommen95, Idaholewis, Sprite, spbonus
70746 Registered Users
41 registered members (carlprop, bbhero, blufeb95, 2strokeNorthstar, 928, Blkstanger, 4 invisible), 1,267 guests, and 19 spiders.
Topics301,631
Posts5,199,530
Members70,746
power flow pf-1 oil additive?? #3177211 11/03/13 01:36 PM
dixon700 Offline OP
At work last night a driver wanted this additive added to his transmission. He said its what the army is running in everything. It said it contains no moly, Teflon, sulfur, and other things I can't remember... Has anyone ever heard of this additive? Is it just more snake oil? It had claims similar to motor kote.
04.5ram CTD lots of parts delvac15w-40 just delvac next time Donaldson elf7349 02 elantra gt castrol edge10w-30 oem filter
Re: power flow pf-1 oil additive?? [Re: dixon700] #3177212 11/03/13 01:37 PM
dixon700 Offline OP
If the bottle is still there I'll get a pic of it.
Re: power flow pf-1 oil additive?? [Re: dixon700] #3177250 11/03/13 02:14 PM
O
oilboy123 Offline
O
Usually the military makes good decisions, but......
“Loyalty to country ALWAYS. Loyalty to government, when it deserves it.”
― Mark Twain
Re: power flow pf-1 oil additive?? [Re: oilboy123] #3177264 11/03/13 02:37 PM
crazyoildude Offline
Makes good decisions ??? i wish i could get into that here but it is against Bitog policy and with good reason..
Check To See That The Oil Jugs You Buy Have The Exact Amount Of Oil In Them And Have An Inner Seal Under The Cap. I Use Mobil 1 And Fram Ultra Filters
Re: power flow pf-1 oil additive?? [Re: oilboy123] #3177331 11/03/13 03:53 PM
Donald Offline
Army intelligence is an oxymoron.
2015 Ford F-250 w/Powerstroke
Re: power flow pf-1 oil additive?? [Re: dixon700] #3177332 11/03/13 03:53 PM
Donald Offline
Buy high quality ATF like Redline or Amsoil and forget the additives.
Re: power flow pf-1 oil additive?? [Re: dixon700] #3177360 11/03/13 04:39 PM
T
Trajan Offline
T
Keep in mind that if they are using one, it's from the lowest bidder.
Re: power flow pf-1 oil additive?? [Re: dixon700] #3178157 11/04/13 12:29 PM
dixon700 Offline OP
I made an error it is power fluids Pf-1 additive. I do not have an auto I shift my own gears. The trans the guy wanted it added to was an Eaton rearranged 10speed. My nv5600 has 9qts of amsoil syncromesh with fast coolers. Anyways this additive states it can be added to engine, trans, rears, and what ever else. I'm just trying to see if it is more false advertising.
Re: power flow pf-1 oil additive?? [Re: dixon700] #3183810 11/10/13 12:21 PM
dixon700 Offline OP
So no one has ever heard anything about this additive? Power fluids pf-1.
(i would fix the title, but I see no way to edit anything...)
Re: power flow pf-1 oil additive?? [Re: dixon700] #3183841 11/10/13 01:08 PM
demarpaint Offline
You can try to notify the mods about the title change you'd like to make. Hit the notify button and give it a shot if you'd like.
God Bless Our Troops
Re: power flow pf-1 oil additive?? [Re: demarpaint] #3184208 11/10/13 07:54 PM
Stelth Offline
Haven't heard of it before, but here it is: Power Fluids PF-1
Experts are often wrong, but rarely in doubt.
Re: power flow pf-1 oil additive?? [Re: dixon700] #3392685 06/09/14 01:57 AM
dixon700 Offline OP
I shelled out my nv5600. I don't believe I'm going to try any sort of additives anymore for anything and just try to stick to good fluids.
Re: power flow pf-1 oil additive?? [Re: dixon700] #3392755 06/09/14 06:16 AM
dave5358 Offline
1) Never heard of it.
2) The Power Flow PF-1 website is basically worthless (surprise, surprise). From the description, they might be using MoS2, except that they mention "contains no solids" and "no build-up".
3) The MSDS doesn't reveal much except this: "APPEARANCE / ODOR: Amber / Hydrocarbon". If it's amber, then it probably does not contain MoS2. Maybe some other form of moly??
4) If you rule out MoS2, then it could be just mineral oil (à la Z-Max - >99% mineral oil).
5) Or, there's a chance they are using PTFE (Teflon) - a popular magic ingredient - in which event you might want to use it as a shelf decoration or paper weight.
6) As for the U S Army using it, that's a definite negative.
7) Good luck trying to buy some. If you go to their 'where to buy' page, it is almost empty.
Re: power flow pf-1 oil additive?? [Re: dixon700] #3393160 06/09/14 03:02 PM
MolaKule Offline
Global Moderator
Global Moderator
Quote:
A smooth, oiled surface is more slippery and creates less friction than a non-oiled surface.
Ya Think? crzy
Charlie Eppes: "Larry, have a minute?"
Dr. Larry Fleinhardt: "Yes. Because we all have exactly the same number of minutes at all times, do we not?" From NUMB3RS
Re: power flow pf-1 oil additive?? [Re: dixon700] #3393180 06/09/14 03:29 PM
Clevy Offline
The write up claims no moly,so scratch that.
I'm leery of anything called a metal conditioner. How do you condition metal.
I'm betting it's a chlorinated paraffin which we all know is bad.
By the sounds of the description of how it works I'm betting chlorinated parafin.
Therefore don't use. It's junk.
2006 Charger RT
Miles x 2 per oil filter
