Originally Posted By: tig1
Originally Posted By: Clevy
Honestly. Use a cheap Dino 5w-30 and change it often. Synthetic oil isn't any "slipperier" than Dino. It does however last longer. Unless you plan on extending your drain interval or have a sludged up motor I suggest just use Dino and change it every fall. Not really a "need" for a high tech oil in this application. If you have a half a quart of synth laying around I would use it instead of buying some but I wouldn't go out of my way to use synthetic. Jmo
You said"synthetic oil isn't any slipperly than dino" Well, actually a quality synthetic does reduce friction in an engine to a small degree. This is why there
is a slight increase in MPG in enines using it, and a small decrease in oil temps over dino. Will dino work well in an engine like this? Absolutely. But his question was, using M1 be a good idea or not.
Try putting pyb vs mobil 1 of the same viscosity,let's say 5w-30. The mobil 1 int more slippery however the additive pack is stronger and meant to last longer. If they both contain the same amount of moly they are the same "slippery". Zddp is anti-wear not anti-friction. There is a difference. In a cars sophisticated fuel injection system a slight mpg increase may happen however a small carburated motor will see no benefit.
I have seen a fuel consumption decrease by adding acetone to the fuel but oil hadn't changed any run times. I make my living with these things. They run 10 hours a day,6 days a week. I have used synthetics in the hope of some form of cost savings however the product costs more and still needs to be changed every 100 hours.
I have tried everything from 2 stroke oil in the fuel as an upper cylinder lube,supposed fuel saver additives,Lucas ucl and the only significant change was realized with acetone. 1 ounce per 10 liters of fuel extends run times by 20% repeatably. I also used the lubro-moly additive with mixed results.
This particular application will only cost the op more for the oil because it still needs to be changed at 100 hours.
