Originally Posted By: Nayov
What's the story behind these? Every 16" tire I mount says (on tire) not to use on 16.5" rims. So I assume 16.5" tires / rims were used in the old daze. When did 16.5 become obsolete, and what examples of vehicles used these?
The idea behind half inch sizes is to be able to use essentially the same tire and go from tubetype to tubeless. In the big trucks, that means going from a 20" to a 22.5", or 22" to a 24.5".
But in smaller trucks it means going from 16 to 16.5"
16.5's first appeared in the 1960's. My books do not go past 1971 so I can't tell you more exact than that.
They were designed to replace 16" on Ford F-250's and 350's. Where we use LT tires now.
At the time, there was a transition in tire sizing taking place: In passenger cars, the sizing was going from Super Low Section (82 aspect ratio - 7.75-14, 8.55-15) to AlphaNumeric (F78-14, G70-15) In pickups, the smaller ones (F-150's C1500's) used passenger car sizes, but the larger ones (250's,350's. 2500's, 3500's) weren't really changing. They used Low Section (88 aspect ratio: 7.00-15, 7.50-16) - except to say that the half sized tires were being introduced.
Why half size? So tubeless and tubetype would be easy to distinguish. 16" rims could be both ways, and it was causing confusion.
It didn't take too long to discover that people could put 16" tires on 16.5" rims - and because the diameters are different, the beads wouldn't seat. Some people continued to add pressure and sometimes the tires exploded. Numerous fatalities.
So the industry transitioned to kind of tire sizing we see now. Vehicle manufacturers quit using them in the early 1980's.
Unfortunately, these wheels are still in existence.
Originally Posted By: clinebarger
My '69 C20 Chevy has 16.5" tires with Split rims.
No, it doesn't. 16.5" tires were designed so they could get rid of split rims - which are very dangerous. All 16.5's are one piece. That was the point of that exercise.
Originally Posted By: Clevy
My 99 silverado had 16.5 rims.
I didn't come that way.
