the new PU might be comparable, though the new PU has better cold flow properties and might have higher TBN but, higher NOACK.
If your talking about old PU, then I think the old PU was better then Amsoil Signature series other then TBN. Though I have personally not seen many UOA on amsoil to the 25k OCI for that extra TBN to matter much. Forget the cost difference in Amsoil motor oil, PU is cheaper...at walmart
Now Amsoil ATF? I love, even in the toughest application where no other ATF improved shift quality, Amsoil ATF definitely worked like a charm, and I love the fact that I could go longer intervals on it as well.
