Originally Posted By: FastGame
Kawasaki service manual:
"Lubrication System
Engine Oil:
Type
SF, SG, SH, SJ or SL class
Viscosity
SAE 40, SAE 30, SAE 10W-30/SAE 10W-40, or
SAE 5W-20
Capacity
1.8 L (1.9 US qt) (When the oil filter is not removed)
2.1 L (2.2 US qt) (When the oil filter is removed)
Level
Operating range (grid area (ADD and FULL)) on dipstick"
IMHO HDEO works best in engines without cat muffler systems that don't call for SM/SN type oils. I use Delo 400 XLE 10W-30 in my JD Z with Kawasaki. Any of the good HD oils should work a treat for you.
You have a lot of choices here. I would run 15W-40 because that's what I run in all my outdoor power equip.
"Lubrication System
Engine Oil:
Type
Viscosity
SAE 5W-20
Capacity
Level
