Hand Sanitizer 1gallon $36 after code
by Touring5 - 03/31/20 08:49 AM
Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
SantiagoT, cabriopeugeot, Z08969, TCU_Adam, deaner1979
71063 Registered Users
113 registered members (55hambone, ANokesPDX, 10ecfarmer, 1978elcamino, 928, 2015_PSD, 16 invisible), 2,113 guests, and 19 spiders.
Topics303,501
Posts5,235,304
Members71,063
Page 2 of 3 1 2 3
Re: a good 30w oil [Re: Andyge] #3371951 05/14/14 09:14 PM
sciphi Offline
Changing it regularly with a 30 weight is lightyears ahead of how most OPE is treated.
Pick what you want, as long as it's Xw-30 or SAE30 and has a API certification from sometime in the 1990's onward.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
Re: a good 30w oil [Re: Ross] #3371978 05/14/14 09:56 PM
R
Reg# 43897 Offline
R
Originally Posted By: Ross
I really like GC 0W30 in mu OPE. Its thick when hot and my snow blower likes it when its below 0F.
Snowblower gets the old green GC each year. Just changed it out yesterday. Not sure just how much original green I have (M04)...
John.
Re: a good 30w oil [Re: Andyge] #3372131 05/15/14 01:59 AM
M
Merkava_4 Offline
M
Valvoline MaxLife 100% pure SAE30.
Ultra rare and exclusive. You can only get it a a NAPA distribution center.
Re: a good 30w oil [Re: Andyge] #3373698 05/16/14 09:41 PM
steve20 Offline
I've been using PYB straight 30 for decades without issues. When QSGB straight 30 goes on sale, I'll use that as well-it's actually got a strong green tint to it (not that it matters-just reminds me of some older spec oils)
Re: a good 30w oil [Re: Andyge] #3373833 05/17/14 03:31 AM
A
Andyge Offline OP
A
just picked up some Shell Rotella T1 SAE 30 .
Andy
Re: a good 30w oil [Re: Andyge] #3374030 05/17/14 11:58 AM
B
bchannell Offline
B
You'll get all kinds of answers. Why? because almost anything will work. Seriously, a small engine will likely run a long, long time on any juice you put in it. Engines that have the correct level and even infrequent changes of oil, will run well for a long life.
My take is as follows:
Best protection: Synthetic with Mobil 1 HM 5w30 and 10w30 as the best. There are a lot of good syns that work fine, if that's your level of cost tolerance. An HDEO syn in the 5w40 is also a fantastic choice.
Fine protection: HDEOs like Rotella or Motorcraft, in either 10w30 or 15w40. You can't go wrong here, strong oils for long life, at a bit less cost.
Completely adequate protection: ST30, or any of the 30wt oils intended for small engines and diesels. These are among the cheapest and protection is super. I like Wolf's Head 30HD. Wolf's head is good oil, $3 a quart and easily available around these parts.
Re: a good 30w oil [Re: Andyge] #3374541 05/18/14 03:23 AM
05LGTLtd Offline
Running MS5k 10w-30 in my craftsman mower. Need to change again for the year. Seems to work.
Re: a good 30w oil [Re: 05LGTLtd] #3375023 05/18/14 07:09 PM
M
Merkava_4 Offline
M
I'm running that in my car. When I bought it, they did't tell me it was lawnmower oil. duh
Re: a good 30w oil [Re: Andyge] #3375272 05/18/14 11:46 PM
SS1970chrysler Offline
I just use ST HD30
93 Towncar- Rotella T-30+M.Craft
93 CrownVic- QSGB 10w-30+M.Craft
78 LTD- S.Pro XHD30+Bosch
Re: a good 30w oil [Re: dparm] #3375435 05/19/14 08:52 AM
B
Boss302fan Offline
B
Originally Posted By: dparm
A lot of guys like Rotella T 10w30. Very stout formula and pretty cheap, too.
Ditto...
John P
Wisconsin
2018 Subaru Outback 3.6R Limited
2006 GS 430
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
Re: a good 30w oil [Re: Kuato] #3377815 05/21/14 08:47 PM
B
buck91 Offline
B
Originally Posted By: Kuato
I simply use the xxW30 we are putting into our vehicles. If it lubricates well there, it will do well in the mower, too.
Ditto. Got no proof for or against other than no failures or issues to date.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: a good 30w oil [Re: Andyge] #3378502 05/22/14 04:22 PM
B
barkingspider Offline
B
My lawn starts better w 10w30 than sae30 so I just use left over oil from car oil. Usually syn 5 or 10w30. And I change the lawn mower oil once a year
04 Avalanche Z71 4x4
Re: a good 30w oil [Re: Andyge] #3381307 05/26/14 06:05 AM
T
Toros Offline
T
Was using Wolfs Head HD30but switched to ST HD30. I would use any 10w-30 but those two are spec for most of my mowers. I use 5w-30 my snowblower...usually what remains from an OC from one of my cars in winter.
Never had 4 stroke equipment issues related to oil.
Re: a good 30w oil [Re: Andyge] #3381778 05/26/14 08:43 PM
G
gman2304 Offline
G
Supertech 30wt HD.
Re: a good 30w oil [Re: Andyge] #3386351 06/01/14 03:24 PM
P
ProStreetCamaro Offline
P
Amsoil ACD 10W-30/30WT. Has no viscosity modifiers at all, is high in zddp for the flat tappet cams, high detergents to keep these hot running small dirty engines clean and is a group IV oil. Best oil I have ever run in these small engines. BTW I do lawn care commercially (my business) for the last 31 years. Been there done that.
Page 2 of 3 1 2 3
