Originally Posted By: ZeeOSix
Originally Posted By: Clevy
I cannot say for sure that every manufacturer is the same as far as firing and position however I did work on a triumph tr7 and I'm positive that engine had the 2 center cylinders in the exact same position and the 2 outside cylinders also in the same position. So the outsides would fire simultaneously and so would the center pistons.
Just because two of the four pistons were at the top or bottom at the same time doesn't mean they both fired at that same time. A piston is at TDC twice and BDC twice in it's 4-stroke process. Multi-cylinder engines typically do not fire two or more pistons at the same time because it causes too much vibration. The pistons are usually fired by (720 degrees/# of cylinders) apart to give as many power pulses into the crankshaft as possible per crank revolution.
Ohhhhhhhh.
Ok. So one of the pair was firing while the other was compressing.
Gotcha.
I stand corrected. Thanks zo6
Ohhhhhhhh.
Gotcha.
