AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1ยข at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
25 registered members (FordCapriDriver, Falcon_LS, 2000Trooper, CharlieBauer, AndyB, carlprop, 2 invisible), 712 guests, and 17 spiders.
Topics297,569
Posts5,118,193
Members69,899
Most Online3,589
Nov 2nd, 2019
Oil recommendation for acura/honda k20 engine #3337428 04/09/14 01:43 AM
M
mauric3 Offline OP
M
hey guys! i have a csx type s with k20 engine that is identical to a 2006-2011 honda civic si with k20 engine.. Car calls for 5w30... So what would be a good 5w30 to use on this engine? Also, would following the MM be a good idea or changing the oil earlier might be better since the k20 is a pretty high reving engine.. I usually hit vtec maybe once or twice a day ....
Is the motul x clean 5w30 gonna be a good oil for this engine?
I actually just put in a PP pureplus 5w30 recently since i got the car used and just wanted to put in a synthetic oil for peace of mind..Also, i'm actually thinking of just running the oil for maybe around 3k KM to just sort of clean the engine and do another 3k km with a full synthetic oil and then gonna do either 5k or 6k km interval or follow the MM of the car?
Specific interval to change oil or follow the MM of the car?
Thanks!
2010 Acura CSX Type-S K20Z3 - Royal Purple HPS 5w30 with Mobil 1 m110 oil filter
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3337461 04/09/14 05:28 AM
H
Hokiefyd Offline
H
Any quality 5W-30 will work well. I would personally choose any over-the-counter (OTC) synthetic 5W-30...most all of these will be dexos1 certified and also meet Honda HTO-06. Neither of these specifications are required for your car, but they are marks of very good oil.
Examples of good OTC oils in this grade include Mobil 1, Pennzoil Platinum (any of the flavors), Quaker State Ultimate Durability, Valvoline SynPower, Castrol Edge (any of the flavors), etc. Lots of excellent choices in the 5W-30 grade.
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3337466 04/09/14 05:36 AM
B
bigt61 Offline
B
Keep using the PP pureplus 5w30 and follow the MM. Keep it topped off and you'll be fine.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3337622 04/09/14 08:38 AM
B
bepperb Offline
B
3000 kilometers? That's crazy. Maybe one early drain at 6000km and then follow the maintenance minder or 10,000 km. The Honda K series is a pretty bulletproof engine family, I wouldn't be too worried about the particular oil you use.
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3337646 04/09/14 09:03 AM
E
EdwardC Offline
E
How many miles are on the car now? Doing a 3000km (1864mi) OCI to clean is just wasting the full synthetic, in my opinion.
Since you're running a full synthetic, I would just go straight to what the MM tells you to do. I believe they're calibrated for mineral oil, so you'll be very conservative with synthetic use.
Save the oil change and spend the $25 on other maintenance items.
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3337713 04/09/14 10:22 AM
9
901Memphis Offline
9
Follow the MM down to 15%, use a good filter too like a Fram Ultra and leave it on for a few intervals since they go up to 15,000 miles.
2012 Chevy Cruze LT 1.4T - 69k - M1HM 5w30 + Fram Ultra
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3338358 04/10/14 02:13 AM
M
mauric3 Offline OP
M
Car is at around 42k KM right now.. Don't really know the maintenance of the previous owner that's why i put synthetic oil right away after i got it...
Is Motul xclean 5w30 a good oil for this engine?
Is motul oil gonna be alright to run til 15% oil life on the MM?
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3346144 04/18/14 02:17 AM
M
mauric3 Offline OP
M
Is motul a good oil for this engine?
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3346159 04/18/14 03:53 AM
G
Garak Offline
G
I'm deathly afraid to ask the price.
Plain, simple Garak.
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3346234 04/18/14 06:53 AM
B
Boss302fan Offline
B
I used 5W30 PP in ours and it worked fantastic. The engine was very clean... Very smooth running with this synthetic oil.
John P
Wisconsin
2018 Subaru Outback 3.6R Limited
2006 GS 430
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3346309 04/18/14 08:24 AM
subaroo Offline
great engine...not picky... use any good quality oil stated above and sleep very well at night.
2012 Suburu Outback 2.5i Caterham Blend Napa Gold 7055
2014 Jeep Grand Cherokee Limited 3.6L PYB 5w20 oem filter
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3377403 05/21/14 12:38 PM
M
mauric3 Offline OP
M
Which oil is gonna be better choice for the k20 engine?
Amsoil SS0 5w30, Royal Purple 5w30 or Royal Purple HPS 5w30?
Thanks!
Re: Oil recommendation for acura/honda k20 engine [Re: Garak] #3377492 05/21/14 02:16 PM
W
wemay Offline
W
You and me both...
2018 KIA Sportage LX AWD
MSS 5W30, PL14459
2013 Hyundai Santa Fe Sport 2.0T
M1AP 5W30, OEM
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3377495 05/21/14 02:18 PM
W
wemay Offline
W
Thanks!
Of the three... My choice is the HPS. But we are splitting hairs.
MSS 5W30, PL14459
M1AP 5W30, OEM
Re: Oil recommendation for acura/honda k20 engine [Re: mauric3] #3377504 05/21/14 02:34 PM
Y
yvon_la Offline
Y
On paper mobil delvac1 le5w30 seems legit,but without virgin oil analysis it is hard to recommend it.amzoil seem to always be one of the top 10 (safe bet)so i would probably use amzoil
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
